Originally Posted by
kosha
Thanks. I read that particular thread. I do not want to add XPA-5 if I buy the 906. UPA-7 is not at all comparable to XPA-5.
If I go with my option (1) I will loose the balanced outputs and the unit will likely be hot. What else I will be missing with option (1)?
honestly... try using the 906 first. that amp is a monster of a beast
If i were you i just save the money.... and buy other things... because I don't think you will hear huge difference unless you crank up everything really loud....you 'might' hear a difference.
Usually external amps are paired with less $$ receivers... or you are trying to run a movie theater in you house. I don't know what kind of set up you have, and do you really need something that big?? But the 906 is no slouch, and i m sure it has no problems powering all your speakers even in a theater setting!!! So I will try that out first and see how it goes before blowing $850 on the XPA-5 ...
