AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Looking for a receiver that inputs HDMI but outputs that signal via Component
post #1 of 13
I am looking for a receiver (such as a Denon 1610) which will allow me to input various signals via HDMI (PS3, DirecTV HD DVR, etc) but will output those same video signals via Component. Unfortunately, the TV I want to connect this to does not have HDMI, it only has component inputs. Do such receivers even exist? I know there are other items that can do this such as THIS, but I'd prefer it to be in a receiver.
Thanks in advance.
post #2 of 13
HDMI to component exists in one product I know of, the Emotiva pre pro, which has not shipped yet I think.
And there's going to be limitations. It likely can't output a component signal if the HDMI signal is protected.
post #3 of 13
I am guessing the easier solution would be to just buy a new TV.
post #4 of 13
I can think of a number of compelling reasons to upgrade the display. "Easy" isn't one of them.
post #5 of 13
Occam's razor says that the simplest solution is often the best solution. Buying a new tv would be the simplest solution.
post #6 of 13
But maybe not the cheapest
post #7 of 13
I dunno, getting a TV with 3 HDMI inputs sounds like it could end up being cheaper than getting a receiver that can do what I want it do to (if one existed, which doesn't seem to be the case).
post #8 of 13
Well, if you were willing to cope with component video, why not simply connect all devices with component video? Does your receiver switch component video (thus making things a bit simpler.)
post #9 of 13
If you're wanting to keep the TV (or if you are a CRT front projector person), you could get an HDFury. It takes in HDMI, resolves all the HDCP, and spits out component. Works awesome - I have a buddy who uses one.
Then you could use any receiver you want.
Costs about $150 right now.
http://www.curtpalme.com/HDFury2.shtm
post #10 of 13
I think the current NAD receivers, T7x5 models do.
post #11 of 13
The corollary to Occam's razor says "Any excuse to buy new Home Theater equipment is a good excuse."
post #12 of 13
There is no such thing and even if there was it probably would be forbidden with the copyright protection that comes as part of the game with HDMI.
post #13 of 13
That was correct before the Emotiva UMC-1. As I mentioned above, or thought I did, the UMC-1 does have this feature. I assume it can only convert non protected streams as I also I think I mentioned above
