build a test door and see if you like it....best way to judge that kind of thing. i personally think rails and stiles need to be symmetrical.
regarding ripping the wood down, you can do it, but you will need to run it through a jointer afterwards....but i usually just use my router table and offset one side of the fence by 1/16 and use a large straight bit.
be careful 1x3 looks too wide at first then when you add profiles to both sides (if that is the plan) it can start to look thin quickly!
I love making cabinets fwiw....so do what you want with the sizes, there is no correct way...but i would test the mix and match first to make sure it is visually appealing. (actually, when making raised panels, it should be a ratio of about 5:1 for time spent testing/setting up versus time spent actually running through the router!)
