I stacked the top and bottom of the front wall cabinet so I could rough mark where the 1x2 dividers will go. That will hopefully help keep me square and give me some to eye as I align the top and bottom.
Then I installed some corner supports. I wished I wouldn't have used the soft pine, but I had sitting there. I added some cleats to help keep the vertical 3/4" mdf supports square.
I used the Kreg drill bit to make these recessed screw holes.
Finally, I attached the top to the corner supports to get the two pieces aligned properly. The 4x4's are just temporary. I need to install the 1x2's first before I can add the 3/4" MDF supports behind them.
