AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › The Cinemar Home Theater Construction Thread
The Cinemar Home Theater Construction Thread - Page 54
post #1591 of 2757
Originally Posted by mcascio View Post
No. The photos are straight from the camera/lens without any manipulation.
I guess that s'plaines the cost of the lens. Really nice!
post #1592 of 2757
I worked till about 2am last night in the theater. I finished installing all of the lower side column mouldings.
I only had three different moulding sizes to cut. So I used some scrap wood clamped to the fence to act as a stop which makes getting accurate cuts a breeze.
Here's the larger cut.
To cut the smaller pieces, I just used another block cut to size that I could easily add remove to the fence allowing me to switch freely between the two sizes without reclamping.
Next, I remarked my column sides where the moulding will be installed. I was fortunate enough to use 2" from the front of the column which made it pretty easy to just flush my 2" square against the face and trace my line.
I made everything square off the face of the column and didn't worry about breaking out a level.
I built this jig so I could clamp it to the face and have a nice hard edge to set my first long piece of moulding.
A little glue before installing.
Then I set it against my block and nailed down.
Then I glued up the two smaller pieces. Followed by the final larger right moulding.
Then nailed while holding the pieces. Make sure you shoot straight otherwise the moulding could shift. I learned to start installing everything in place that are not as visible in the room. So by time I made it to the more visible parts I worked out any kinks.
This putty knife worked nice to remove any excess glue.
Finally, the completed project.
post #1593 of 2757
Yo! Those columns are handsome! Nice job!
Oh and that stop block trick is essential. The day I learned that it changed my woodworking forever!
post #1594 of 2757
You suck so bad at being bad at this... Yea, read it again.
I am always AMAZED at your woodworking skills and the design and execution of your theater build.
post #1595 of 2757
Yeah. Just wish I had more in my arsenal. It would probably make me more efficient.
post #1596 of 2757
That's too funny. But isn't that a double negative?
post #1597 of 2757
So I'm going to attempt installing the base boards now. I'm planning to go with a 1/2" pad and 1/4" thick carpet (Quadrate).
Given the carpet is pretty thin...I'm assuming I should raise the baseboard about 3/8" off the ground. Does that sound right?
post #1598 of 2757
Yup, double negative makes it a positive.
post #1599 of 2757
I've never done baseboard with carpet before but it sounds a little tight? Don't forget you're going to probably put shoe moulding over the baseboard once the carpet is in to cover any gaps. In addition I don't know how level your floor is, you may have some slight peaks and valleys.
post #1600 of 2757
Hi Larry. I already started setting it a hair above 3/8". I think the carpet will ramp down from the 1/2" pad over the tack strip and then hopefully squeeze under the base. I'm pretty sure you only use base shoe on hard surfaces like tile or hardwood. I know the carpet guy initially said he will need to ramp up to the 3/4" bullnose because it will drop down on the tack strip.
Absolute worst case, I could go with a 3/8" pad...although not ideal for sound.
post #1601 of 2757
Haven't had carpet in years. Looking forward to how yours turns out so I know what to do
post #1602 of 2757
I was hoping to finish up the base boards over the weekend but it didn't happen with it being Easter weekend.
I was able to make a big dent in the room though.
post #1603 of 2757
i must say this the highlight of my mondays when i return to work is to check out your progress...just stunning, my build is starting this weekend and your build definality gets the creative juices flowing.
post #1604 of 2757
Looking great Mario! Congrats on getting some serious work done in the room.
post #1605 of 2757
Originally Posted by snickers1 View Post
i must say this the highlight of my mondays when i return to work is to check out your progress....
+1!
post #1606 of 2757
Maybe you've already answered this, but what color are you planning to paint the chair rail and baseboard moulding (or are you leaving them white?)?
post #1607 of 2757
Plan is still to have the ceiling painted by that guy on the forum?
I sent him an e-mail several months ago and never received a response. Last I checked he hasn't checked in on his thread in a while
post #1608 of 2757
Thanks snickers1. Good luck with your build / journey. It's a long road.
post #1609 of 2757
Thanks. It looks like you are doing the same. Remember, it's not a race.
post #1610 of 2757
They will both be painted black. The chair rail came primed already and the baseboard was primed and painted and left over from the basement project.
post #1611 of 2757
Hi Larry. I did just recently correspond with him. I'd like to try and get the ceiling done prior to the carpet install if possible.
I would email him again. I know he does travel alot and has a hard time keeping up with all the inquiries.
post #1612 of 2757
I only had a couple hours to spend in the theater last night.
I completed cutting all the baseboard along a set of stairs.
post #1613 of 2757
I made another big push last night after dinner until about 2am.
I finished putting up all the base for now at least until the door is installed.
I also started on the mouldings in between the columns.
First I cut to size all the vertical pieces since they were all the same size. Trimmed here and there to ensure they were identical in size.
I used my base (4 1/4" tall) as my spacer all around. I started by tracing my shape inbetween the columns on the MDF. Since I made sure to mount the chair rail level to the ground I went off of that as my guide since it would be consistent as opposed to using the base board which fluctuates in height with the ground.
I dabbed a bit of glue on the backside of the moulding, especially in the corners, and pushed the top piece snug against my base board spacer to ensure it was straight and level. Then brad nailed.
Next, I glued the back side and joints of the two side pieces and set in place.
Then finally glued the bottom piece and placed on the wall. By time you finish positioning all the corners so they are square...the glue should start doing it's magic.
Finally...I brad nailed the remaining sides and bottom to the wall. Make sure to go straight so the moulding doesn't slide.
post #1614 of 2757
Looks great, Mario.
post #1615 of 2757
I'm looking for a little feedback on the moulding between the chair rail, base and columns in these two renders.
I need to decide whether to have the moulding follow the stairs with an "L" shape or just run it straight. This would be the only place this occurs in the room if I decide to make an "L" shape.
Any thoughts?
"L" Shape
Straight
post #1616 of 2757
Go with the "L"
post #1617 of 2757
Originally Posted by dtupperjr View Post
Go with the "L"
+1 The L is a nice detail, IMO.
post #1618 of 2757
I vote for L too. By the way, haven't posted here in a while but I have been watching and everything looks really great Mario! Congrats on a great project so far!
post #1619 of 2757
+1. The L shape is architecturally better. Follows the contour perfectly.
post #1620 of 2757
I'd go with the "L" as well. It'll look swell.
Bud
