Originally Posted by mcascio
Another question for the pros. I'm looking to finalize the screen size and aspect ratio.
I've maxed out my height at about 58" and was planning on going with a 2.35 aspect at a 136" wide.
I have some extra space on the sides where I could bump it to a 2.40 aspect to eat up the side space a bit more.
But my question is with the Panasonic AE4000U and how it handles switching between 2.35 and 2.40 content. Will it allow me to fill the screen in both scenarios?
Hopefully some of you AE4000U owners can offer some advice.
If need be, I can automate sending a Memory Load command based on the aspect ratio of each movie during movie selection.
Hello Mcascio, i have a AE4000u and love the projector, my room is similar to yours in size (15'x24').The panasonic will auto two aspect ratios, however you can do other aspects but will have to go into the menu for those . If you have 58" max on height then you'll be limited as far as how wide you can go. For instance, my screen is 2.35 aspect, 126"wide by 54"high and border about 1.75" times two. In your case, if i understand correctly, you have 58" of height with extra only at the width. First you need to add about 4" for the border of the frame. So for 136" wide screen the height is actually 57.87". In my room the picture looks huge at 10.5 feet, you may wanna give the screen some more thought. Your build is outstanding you get very high marks. I seldom post anything but have been a forum daily reader from the very beginning of avscience since my friend Alan Gouger started it years ago. Hope this helps and keep the photos coming i love this very expensive hobbie, luckly my wife is on board. I really should post pictures of my theater.
