AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › The Cinemar Home Theater Construction Thread
The Cinemar Home Theater Construction Thread - Page 57
post #1681 of 2749
Mario, I was just browsing a moulding catalog from a local (to me) lumber company's website and saw a reference to a "split jamb" I don't know anything about it, but it may be a part of a good solution to your door jamb issue you brought up this weekend. More research will be required (for me anyway). See page 18 in the pdf catalog.
post #1682 of 2749
Re: the door jamb - I was not "wise in the ways of door jambs" when I had mine done (hired out the installation) - so ended up with a standard jamb in a deeper than standard wall:
What I ended up doing was covering the span with fabric covered panels, to help it blend in better. Not as good as having the right depth jamb to begin with, but it came out OK I think:
post #1683 of 2749
Originally Posted by mcascio View Post
I'm using denim instead of OC703.
I'm not sure what I'm going to do yet as far as placing denim all the way around on the upper half.
Given that the ceiling is completely reflective and the lower half of the walls are too, I might just do all denim on the top half. I won't have an opportunity to take the panels down and tweak later like I had hoped.
According to Otoole's book, I thought it recommended alternating or staggering the sound treatments on each side from left to right. I guess the only way for me to find out is to put the denim up as a test before committing.
I haven't gotten into this area as much as I would have liked to since the build is occupying any free time. I'm open to suggestions.
Like I mentioned earlier...I was thining of adding 6" thick of OC703 in the column lower portions too. I can even add some above and below the speakers in the columns.
I think room acoustics and acoustical treatments are among the hardest things for a DIY-er to figure out, in part because there is no clear concensus on this forum. An awful lot of the recent threads that have discussed acoustical treatments have gotten ugly with personal conflcts.
I consider myself uneducated and naive about these issues. Having said that, it seems to me that most of the professionally prepared acoustical treatment plans that have been posted on this forum show some form of treatment on the first 2/3 or so of the side walls, plus the entire back wall. Take that for whatever it's worth (probably not much).
Everyone seems to agree that every room will benefit from as much bass trapping as can be tolerated aesthetically.
post #1684 of 2749
Humidity and moisture will vary from one basement to the next. So that may be why yours was unaffected. I'll probably go with the roofing felt against the concrete since it can't hurt.
Another option would be matching granite from my back bar.
Granite or something that matches the tiles in the basement
post #1685 of 2749
Thanks for the link. It looks like you would use a split jamb in a retro-fit application. But I think in my case, I still need something that spans over two walls. So I'm still left with two separate jambs.
post #1686 of 2749
Thanks Brad. That does look nice and brings up another issue I may need to think about which is do I want to hide the side sound seals.
Or are people just spraying them black? Otherwise I'd have to get creative with some moulding to hide them.
post #1687 of 2749
You couldn't have said it better. I guess to some extent, sound is still a user preference item to some degree which is why they have different sound fields on the amps to emulate different size rooms, halls and arena's. What may sound good to someone may not appeal to another.
As a side note, I still have plenty of room in my front cabinets to add lots of OC703 too for additional bass trapping.
post #1688 of 2749
Ok. Word to the wise.
I didn't make much progress last night.
I was assembling another large fabric frame when I noticed a hole in the fabric. Needless to say, I had already stapled quite a bit of the fabric to the pre-built frame.
Attempts to remove the staples were useless.
I called Fabricmate in hopes of getting some replacement material so I wouldn't run out for my big run at the end.
Apparently when you order the FR701 fabric, there are little tags along the outer edge...which I had seen, but thought they were some type of yard markers and was just removing them along the way.
Turns out those are marked as acceptable tolerance flaws in the material. Apparently an "industry standard". Which is great if you are "in the industry". Not so great if ou learn the hard way. He said they allow like 8 per 60 yards. I had about 6 or 7 in 32 yards.
I'm not sure when a hole in the material became acceptable...but it would have been nice to have some information about what the markers are and what the colors of the markers mean. The contact at Fabricmate wasn't aware of what the colors meant either. I'm assuming it might mean the severity of the flaw.
Fabricmate was unwilling to replace the material because of the "industry standard".
Just thought this might prove helpful to others. I don't think I've seen this topic discussed before in other build threads so hopefully it saves someone else some grief.
I'm not a big fan of rework.
I've got to go back and review all the frames I've built and see if I can spot the flaws that I disregarded when removing the tags. I'm hoping they were more subtle and/or on the edge of the frame rather than a hole in the middle.
post #1689 of 2749
That's certainly good information. Have you tried contacting GOM directly? I would email them a picture of the hole and explain that it is not acceptable to have a hole in the middle of a fabric panel. Can you post a pic of the hole so we have an idea of what you are dealing with?
post #1690 of 2749
I didn't try contacting GOM yet. I may do so. I'll cut what I can from the frame and try to use it elsewhere so I don't get in a bind.
I did email FabricMate a photo although compared to this one it didn't do it justice. I put this up against a window so you can see the light coming through.
Those of you with long runs may want to preplan and pull those long runs from the roll just to make sure you don't come down to the end and have an imperfection in the material.
Had I known what the tags meant, I could have worked around it with some planning. Hopefully whoever reads this can prevent it from happening to them.
post #1691 of 2749
I'm almost half way done with the fabric panels. I thought I'd put them all in to see how it looks.
I also hot glued all the corners where I cut away the extra fabric to prevent them from fraying or getting caught on anything.
post #1692 of 2749
I forgot to post pics of this from the other day of how I've been cutting the fabric.
I've found it easier to cut on the floor using my tile as a straight edge.
I'm using a smaller ripped piece of MDF as the cutting board, rotatry cutting tool and straight edge ruler clamp. The roll itself acts as a nice straight edge to butt the MDF to.
It just so happens the one I documented happens to be the one with the yellow tag that indicates there is a flaw in the material. If you look closely in the picture you can see it.
The rotary cutting tool does a fantastic job of cutting the fabric. Sure beats the expensive scissors I was initially using. I'm hoping the MDF cutting board will keep the blade sharp.
I've also been tracing the fabric frame outlines on the wall before I remove them. Just in case I want to apply the acoustic material to the wall before installing the frame.
post #1693 of 2749
OMG. I love that rotary tool!!! I REALLY needed one. The scissors we used worked of course but it would have been a lot easier.
All things aside, the room is looking gorgeous! I really love the color combinations and style. Cool and classy at the same time.
post #1694 of 2749
NOW you show us the rotary cutting tool......only after I installed/cut nearly 40 yards of fabric lol.
Things are really looking good, the fabric going up on the walls is looking sweet.
post #1695 of 2749
Fortunately, my seals were already black - I think that was an option where I had a choice when I ordered the doors.
post #1696 of 2749
Well to put it kindly, that is ********. Unacceptable!
post #1697 of 2749
I love that red color! That will be an awesome contrast. In fact, I like the real color versus the darker plum reds in your renders. Looking very COOL!
post #1698 of 2749
Mario,
I'm not sure if you answered this already and I haven't really gotten into the finishing stages of my theater so I guess I'm really just asking for educational purposes. But, why didn't you paint the columns, chair rail, and trim before you installed the fabric panels? I'm pretty good at cutting in with a brush, but you must be a cutting-in savant if you can paint that and not allow paint to get on the fabric.
post #1699 of 2749
Yeah. I guess I haven't seen anyone else mention it in a build thread yet. Definitely a must-have.
Thanks for the positive comments too!
post #1700 of 2749
I did get a call and email from my sales rep that I dealt with initially. They gave me some information on how to possibly resolve the defect but also mentioned that they could replace the section of fabric if I returned it.
I think I'll have enough spare though. So hopefully crisis averted.
post #1701 of 2749
It doesn't sound like you ordered the sound proof seals from the Sound Proof company then since they don't sell doors AFAIK.
I guess I could also just spray paint them to blend with the door color.
post #1702 of 2749
Originally Posted by JVoth View Post
Mario,
The panels are currently removable. I just needed some visual motivation to keep going. Once the room is painted, I'll put them back on the wall and make them a bit more permanent.
post #1703 of 2749
Here are some pictures from a wine cellar install. These show another view of a wide jamb. Different considerations for noise and temperature control, but the double pane windows give a view of how the wall width was handled in the door installation.
Attachment 244287
Attachment 244288
Attachment 244289
post #1704 of 2749
Thanks Oronomus,
I'm actually trying to wrap my head around building the custom door jamb now.
Does anyone know if the threshold get built with the jamb?
I'm trying to figure out how wide to make the threshold as well. Typically I think they have the threshold break between surfaces (carpet/wood) underneath the middle of the door. So I'm thinking from the theater side you will only see carpet when the door is closed.
From the foyer side I just need to figure out does the threshold span the entire depth of the two door jambs or not.
I did check out the Oak jambs at Menards and they looked pretty pathetic as far as being straight. Some of them looked like Rainbows they were so bowed. So it looks like I may just roll my own.
post #1705 of 2749
I believe I'm supposed to make the opening a 1/4" larger than my door. I have a 36" door. Does that sound right?
Also, is there one side of the slab door (handle side I believe) that should be angled at 2 degree's? I couldn't really notice it with a square though on my door.
post #1706 of 2749
I just started on my jamb this weekend. The opening should be 1/4" wider than the door. That will leave you with 1/8" on either side of the door so it will close properly. I wouldn't angle unless you have problems with it closing properly.
Here is a pretty good video that talks about the dimensions and give a short "how to". (and no, this isn't me )
Custom Door Jamb
post #1707 of 2749
FYI regarding the rotary cutter Mario is using. I stopped by JoAnn's Fabrics this weekend and they have ALL rotary cutters on 50%! I picked one up after seeing how easy Mario was able to cut his fabric. I think the sale might be over either today or Wed, so I wouldn't wait around.
post #1708 of 2749
I pulled an 18 hour straight bender this weekend and got quite a bit accomplished.
I knocked out all the fabric frames except for the back door entry wall.
I didn't want to have to use long screws for the outlets and have them be all wobbly so I used the 4 gang box that I cut down to a 3/4" depth and fitted it right into the frame.
I ordered an 6"x8" vent cover for my 6" dead vent. Since the vent was larger than the actual opening, I painted the frame and wall black just so you couldn't see anything through the vent.
After stapling the backside. I stapled around the opening I framed earlier. Then lightly hot glued the edges so they couldn't get snagged.
Next I marked my holes.
I dabbed a little hot glue before pre-drilling the holes for the screws to hold the vent.
Now I just need to spray the vent black.
Here are some shots with the fabric frames in place. I used some velcro strips on the bottom side so I could easily remove them from the wall.
Next, I primed the underside of the light tray so it's ready for fabric when the time comes.
I started working on the jambs as well. I decided to go with Poplar for the legs and header. I couldn't justify spending the extra for two jambs in Maple for something that will just get primed and painted.
As usual, it's challenging to find straight stock. So I'll have to swap some boards later.
I made a little jig for the router so I could easily knock out the four dadoes for the top of the jamb legs. I think those are called rabbetts. ?!? They are 3/8" deep and 3/4" wide so the header should fit in there nicely.
I'm at a stand still now until I figure out what my measurements are supposed to be around the door, under the door, jamb to the floor, etc. I couldn't really find anything online that told me how to build a jamb.
post #1709 of 2749
Custom Door Jamb
Thanks. That's the video I've watched many times and found the most helpful.
I'm assuming the top should be 1/8" too?
What about clearance below the door to the threshold?
Should I leave 3/8" to 1/2" below the jamb legs for carpet/pad?
I'm assuming the threshold should get cut to fit inside the jamb? Then I can set my door seals on top of the threshold.
I'm planning to route the edges with a 1/8" round over.
post #1710 of 2749
Unfortunately I paid full price at Hobby Lobby. It wasn't worth the gas money and time though to go back with one of thsoe 50% off competitor coupons.
