AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › The Cinemar Home Theater Construction Thread
The Cinemar Home Theater Construction Thread - Page 72
post #2131 of 2745
I finished rewrapping the front stage cabinet top with the Protostar Hitack flocked light trap material.
I think because it's not as dark as the black velvet it actually blends better next to the painted wood.
My FIL gave all the oak steps and bullnose another coat of floor paint.
The M&K S-5000THX front speakers are now in place. I'll probably need to lower them a tad.
I used Loctite PL Premium to glue down the maple primed threshold. It's 2.5" wide.
The board had a little bow to it so I put some weights on it to keep it flat.
I'll need to cut the shims tonight.
I used 320 fine sanding sponge to sand the surface of the door stop seals from the SoundProofing Company. I completely removed the inside rubber seal and center track by unscrewing all of the screws. Then I wiped down the aluminum with some Naptha to remove any grease from the machining of the screw holes. Next I sprayed a gray primer onto the aluminum. Next, I'll cut to size, then spray a flat back spray on them. Then finally they will be painted with the same eggshell paint as the rest of the room.
I started using some scrap base that I had ripped down. I plan to stack them on top of each other, and then put them into the soffit to help elevate the LED lighting so it's beam casts higher than the black lights up in the soffit. Otherwise, the black lights are creating shadow lines that I don't want to see.
post #2132 of 2745
Originally Posted by nickbuol View Post
You notice that Mario never invited ME...
It's OK though. If you look at his comments to all of you, he really is saying "heck no, you can't come over... I've got the basement to clean, a party to have, the carpet to put down, movies to watch, grass to mow, snow to shovel, vacations to take, dinners to eat, air to breathe before it will be 'ready' for YOU to stop by. Unless you are cowger. Cowger is invited, but really, is (s)he going to fly from California? Not really, so I'm safe there."
I saw that we all schedule a day and just knock on his door. He will be forced to let us in as a group... biggrin.gif
If I was smart, I'd invite everyone over to come check out the theater this weekend...then put some of you to work cleaning the basement while another person starts up the riding lawn mower. The edger is all ready to go too. And for nickbuol, a very special job for only a select few...cleaning the toilets. wink.gif
All kidding aside, you're all invited. Just don't be afraid to get your hands dirty. wink.gif
PS: Changing diapers is not off limits either.
Edited by mcascio - 7/27/12 at 8:01am
post #2133 of 2745
Not sure when you are headed back, but that may work.
We'll be heading back Saturday, 8/11. If not, it's our year to go out there for Christmas. At Christmas we usually fly in out of Milwaukee, so maybe we could work something out then, if not now.
Looking really nice! Wish I had that much space.
post #2134 of 2745
Originally Posted by mcascio View Post
We've got my daughter's first birthday party in the 2nd weekend of August so I'll have to have it ready by then.
post #2135 of 2745
Bummer. That's the day of my daughters first birthday party. We'll be entertaining about 60+ people that day.
Christmas time should work better though if you're in the area.
post #2136 of 2745
Originally Posted by BllDo View Post
post #2137 of 2745
We've got my daughter's first birthday party in the 2nd weekend of August so I'll have to have it ready by then. I still remember we were cutting the cement in the theater for the electrical under the back row seats when my wife called to let me know she's going into labor.
Mario,
Just remember ...
post #2138 of 2745
Too bad it doesn't work out. I'm sure you'll have a great time!
We usually rent a car and get in a couple of days before Christmas and leave a couple of days after, so maybe we can work something out around then.
Enjoy!
Tom
post #2139 of 2745
Originally Posted by hanesian View Post
Mario,
Just remember ...
post #2140 of 2745
Enjoy!
Tom
Cool. I'll let you know if things change for this weekend.
post #2141 of 2745
Here's a quick recap of the weekend.
I cut down the floor box using a dremel in preperation for the carpet.
I used a file to sand the rough edges. There's multiple pieces to the floor box, but the top will have a finished look.
I primed and sprayed flat black on the door seals and door bottom. The Rustoleum Flat black was a good match to the egg shell finish. The satin is a bit too glossy.
It's difficult to see, but the door seals are installed. I cut them with a blade designed to cut metal so I wouldn't ruin my fine finish blade. Be careful, the scrap piece is extremely hot to the touch. I'd recommend assembling everything before priming and painting. I found that the spray paint bubbled up from the heat so I had to sand and give it another coat in some cases.
I had about a 3/16" gap where the header piece was just too short. The header piece came precut (mitered on both ends) to 3' so I think that was the problem. I would think they should miter just one end and let the user cut the other so it can be fit properly.
Here's a shot of the door bottom seal prior to the finish coat. When mounting it I closed the door and just raised it up 3/8". Be sure to screw in the adjustment knob all the way inside the cavity first.
I assembled my boards to raise up the LED's in the soffit so they sit above the black lights and installed them.
I opened up my last tube of acousitcal sealant so I could close the gap between the platform and the concrete foundation.
I swicthed out the led color bars in my Insteon switch to red to see if I like it. It's a bit dimmer, but matches the fabric nicely.
Finally, I had to elevate the Dbox platform actuators. I won't be putting any pad on the platform so you get the maximum effect. So I need to compensate. I made these with channels for the cabling to fit under.
post #2142 of 2745
Ok it's been a while since I've done a composite.
So I thought it would be cool to try with the fabric panels in place now.
Can you tell what's real and what's not?
post #2143 of 2745
post #2144 of 2745
I want to know where you found half a Berkline! I call that's not my seat!
post #2145 of 2745
the tel tell sign lies within the the speaker grill frame leaning against the wall LOL!!!
post #2146 of 2745
post #2147 of 2745
I'm gonna have to start throwing in some 3D frames and power tools to really start to fool you guys then.
post #2148 of 2745
LOL
all jokes aside it looks exactly like the renderings there is nothing i could say that has not been said about how beautiful this theater is turning out
post #2149 of 2745
I almost had a panic attack when I saw the picture with the projector mounted. We all know what happens when you mount the projector. Then I realized that must be part of the render.
Excellent work, Mario.
post #2150 of 2745
LOL
post #2151 of 2745
The projector has been officially mounted and is part of the real portion of the image. However, I won't fall into the trap we've all seen before. This project will get done!
post #2152 of 2745
Here's the division line of the render vs real photo. I made it really simple on you guys. Next one might not be that easy. wink.gif
Here's what the room should look like Thursday after carpet is installed minus the work table and tools.
The top half of the room is real...the carpet and steps are 3D.
post #2153 of 2745
I think I am about as excited for Thursday as you are! Can't wait to see the pics of the carpet and I am sure you will be chomping at the bit to get the screen ans seating in next.
post #2154 of 2745
Mario is there any plans for you to upgrade the M&K ? I think your room deserves something that will do a better job of filling that large space.
post #2155 of 2745
maybe 3 pi speakers for upfront??
post #2156 of 2745
post #2157 of 2745
I really like that fabric and carpet!
post #2158 of 2745
I've been following the SEOS threads with interest, basically they are the Pi but using a better waveguide.
post #2159 of 2745
Just a-freakin-mazing, Mario! Every time I view this I'm in awe. The countless hours you spent on your 3D model absolutely paid off in spades and gave you the perfect plan to follow. Wow!!!
Bryan
post #2160 of 2745
Awesome I am so impressed every time i visit your thread. Good work!
