AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › The Cinemar Home Theater Construction Thread
The Cinemar Home Theater Construction Thread - Page 86
post #2551 of 2757
Hope everyone had a great Christmas.
These cups showed up under the tree for the theater's front row D-Box seats.
They work great for mixed drinks and soda and prevent spills while sitting in the motion seats.
Edited by mcascio - 12/27/12 at 10:39am
post #2552 of 2757
The new Panasonic PT-AE8000U is installed.
A few first impressions and some comparisons of the PT-AE4000U I previously had in the theater.
Out of the box, the colors seem more vibrant compared to the 4000. There's certainly more light output and brightness.
I can see the walls around the room light up more because of this...but not to the point of it distracting. Everything really seems sharper.
The NORMAL lamp mode seems louder than the PT-AE4000U.
I like the fact that I can now hide the text PROCESSING IMAGE as it switches back and forth between different screen size / formats. Especially for movies like Tron where it's switching within the movie itself.
I was curious to see how much better the 3D has improved. While I have yet to watch an entire movie, I was impressed with the 3D. In fact, I wanted to show my Father In Law what it looked like and I only had one pair of 3D glasses. He actually was so wowed by it that he sat by himself in the theater and watched the entire movie (Ice Age).
I have yet to do much tweaking of the settings aside for some options in 3D.
My perspective is if you are an existing AE4000U owner and not interested in 3D, you might consider holding on to your 4000 for a while - or just upgrade to the 7000.
But I think the jump in price from the AE4000U to the AE8000U is definitely worth it if you also want to dive into 3D. You'll have to figure in the cost of the 3D glasses though too. They aren't cheap.
Hope that helps others make a decision.
post #2553 of 2757
GREAT info on the 8000, Mario, thanks! I'm using the 4k today and while I'm tempted to upgrade, I'm not that into 3D just yet.
But your review is just what I was looking for in terms of decision making...
Bryan
post #2554 of 2757
Bryan
Good to hear. I guess if someone didnt have a light controlled room they might make the jump sooner too.
post #2555 of 2757
subscribe
post #2556 of 2757
Ahh great idea Mario
My wife sells promotional items and she is always bringing samples home.
Hmm maybe once the theater is done I can get a logo put on it
post #2557 of 2757
Larry.
That's a great idea. I like the idea of branded cups for the theater.
Let me know if your wife has similar cups as promotional items and if they can be ordered in small quantities.
I did some Koozies branded with our themed annual outdoor party logo I created a few years back and it was a big success.
post #2558 of 2757
Tervis will insert your object into their tumbler. Can't beat the quality.
post #2559 of 2757
Be sure to check the size of your cup holders. The ones in my Berkline 13175s are not big enough to hold a 24 oz Tervis tumbler, and the bases on their 10oz, 12oz and 16oz tumblers aren't much smaller. HopefulFred is right though, you can't beat the quality.
post #2560 of 2757
Mario
How did you attach the fabric screens to your columns and picture frames?
It looks like the moulding is nailed to the framing/mdf and your friction fitting the fabric in???
I picked out some panel moulding the other day, it's not as nice as I would like but not bad. I've been racking my brain on how I'm going to make removable screens for the columns
post #2561 of 2757
Larry.
I'll have her look into it. Usually they are quantities prohibitive to what a homeowner would need but I'll look anyhow smile.gif
post #2562 of 2757
Mario
Hi Larry,
If you are referring to the moulding frames on the front lower section of the columns.
I build the frames first. Then attached the fabric to the frames with staples. Then attached the frames with a couple finish nails.
Here's the link to the details:
http://www.avsforum.com/t/1208912/the-cinemar-home-theater-construction-thread/2010#post_22162038
And some pics from that post:
I used different techniques for the sides. Let me know if you were referring to something else.
The top half where I needed access for the speakers are removable. I used magnets to hold the frames in.
post #2563 of 2757
Good to know.
I'm guessing your Berkline cup holders are the same as my berkline's.
I'd be interested int he 16oz tumbler's. Anyone know for sure whether they'll fit into the Berkline cup holders?
post #2564 of 2757
Hi Larry,
I was reviewing that post last night. I'm still not understanding how you did it.
The picture with the moulding facing down with the fabric stapled to it, is the fabric stapled right to the moulding or do you have a small frame attached to the moulding?
Where and how did you attach the magnets?
post #2565 of 2757
Hi Larry,
In the above photo, I attached the fabric to the moulding...no frame was needed because the moulding itself was beefy enough. These frames are the small ones located on the front of each of my columns on the lower half. They are not removable. I finish nailed them right to the column. Initally I was going to make them removable, but it wasn't that big of a deal.
Now the top half of the columns have removable frames using magnets. The frames were plastic and bought from parts-express.
This post goes into details of how I build the frames and attached magnets:
http://www.avsforum.com/t/1208912/the-cinemar-home-theater-construction-thread/900#post_21251596
post #2566 of 2757
Good to know.
I picked up a 16oz Tervis Tumbler at the local Bed Bath and Beyond.
I can confirm that they do fit in my Berkline cup holders.
Has anyone else done a custom Tervis tumbler for their theater?
I would think you wouldn't want them all to be the same so that you know which cup is yours. It might be cool to have movie themed cups but due to copyright issues, that won't work. I did see some Star Wars tumblers on ebay though.
post #2567 of 2757
Not considering cost (not sure how much it might run), I'd want my name on a marquee, embroidered on a patch and put in the tumbler ...or maybe the name of a movie. Lots of embroidery shops (like a stand in the mall) can probably put something together for you. Maybe they already have a marquee design that they can just insert your text into. You might pay for the custom design, but I bet a 2 inch by 3 inch patch with your name on it (or "JAWS" or "NIGHT OF THE LIVING DEAD" or "MOONRAKER") would be pretty reasonable. I have never used Tervis's custom services.
post #2568 of 2757
I needed an easy way to charge, store and keep safe all the 3D glasses at once.
So I used a rackmount cable management D-ring from Monoprice. I had plenty of space left over in my Patch Panel cabinet in the theater so it worked out great.
I used this 10 port USB hub and a power supply.
Then routed all the cables up to the D-rings.
I only plan on stocking seven 3D glasses, but I could easily hold 10 with this sytem if not more. It's nice to be able to charge, store and keep the glasses protected all at the same time.
Thought this might be helpful to other's with 3D glasses.
post #2569 of 2757
Great idea.
Mario you did an amazing job, looks extremely professional, actually probably better then most 100k HTs!
post #2570 of 2757
Hi Mario,
I am just about to start on my new cinema room. I am looking at the Panasonic PT-AE8000U but the sales rep is trying to push me toward the JVC DLA-X55.
I will also have a room similar in size to yourself and considering an 150" 2:35.1 screen.
Could you please tell me your projected heigh x width for 2:35.1 and 16.9?
Also did you contemplate any other brands than panasonic before choosing? What was the main reasons for the decision?
Cheers from OZ.
post #2571 of 2757
Man, yet another ingenious solution that keeps this theater just top-notch... Nice work!! smile.gif
post #2572 of 2757
Mario,
Love the 3D glasses idea. Was thinking of something similar, but your solution is, well, better. Which 10-port hub did you use? I've found several similar on The Big River, but can't find an exact match (perhaps vendor pictures are not accurate.)
post #2573 of 2757
Originally Posted by tbraden32 View Post
Great idea.
Wow. Thanks. I really appreciate the compliment.
post #2574 of 2757
Originally Posted by brendanb21 View Post
Hi Mario,
Cheers from OZ.
Hi brendanb21,
I really liked my Panasonic AE-4000u so I knew I was going to like the Panasonic AE8000U. I knew my current mount would work no problem and I also looked at all the reviews on the Ae8000U. So I was pretty confident with that model from the get go. I like the fact that it can auto-switch between 2.35 and 16:9 content which some other mfg's didn't have. I liked the added 3D ability and the rave reviews it got over other mfg's.
I looked at comparably priced Sony, JVC and Epson models. But just from the online reviews I read I felt more comfortable with the AE8000U. I'm very happy with my decision, but I never had a chance to see the others in action.
My 2.35 screen is 136" wide by 57.8" tall.
Ideally you could see both together.
post #2575 of 2757
Thanks as usual cowger!
post #2576 of 2757
Originally Posted by roknrol View Post
Mario,
I really lucked out having all the extra space in my patch panel cabinet in the theater. Beats having to drag them to my media closet to store and charge.
Do a search on ebay for 10 port usb hub and I'm sure you'll find the same one I bought.
post #2577 of 2757
Thanks Mario for the reply,
The sales guy i have been dealing with told me the that the he didnt think the panny could light up a 140" wide screen good enough and 3D would be too dark.
From your pics thou it seems plenty bright.
Cheers again.
post #2578 of 2757
Cheers again.
I don't have a way to read how bright my projector is...plus it's uncalibrated. From what I understand a calibrated projector will most likely produce less light.
To my eye, out of the box, it's certainly brighter than my AE4000U was. And there are certain scenes where they go from dark to bright that are almost blinding and you have to look away.
This my unprofessional opinion though. Someone who has installed both of the models in question would be able to provide more helpful information.
I've been running in normal mode. I could probably get away with ECO mode to quiet the fan but have opted not to.
It's like everything else, unless you have something to compare it to, it's sometimes difficult to make a true assessment.
post #2579 of 2757
3 nights and tired mornings later I finished this amazing build! It looks like you moved from someone that dabbled in carpentry and trim work to an expert within the project. Being someone that learned along the way during their build I can appreciate and respect that! You did an amazing job with the execution of EVERY detail! I am ven more pleased to see that this is a local build here in Kenosha county. I actually stumbled across your CL ad for the 4000 and saw the theater pic. there... I will keep you posted about any local meets and I look forward to perhaps sharing our theater experiences at some point in the future!
Keep up the great work!
post #2580 of 2757
Thanks Wes.
I should start handing out awards to anyone that manages to get through this entire thread from start to finish. smile.gif
I look forward to getting together with you and other locals to share stories and more importantly beer. smile.gif
