AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › The Cinemar Home Theater Construction Thread
The Cinemar Home Theater Construction Thread - Page 87
post #2581 of 2757
This past weekend, I met with my old friend insulation.
I had enough left over from the project to fill the lower half of all the columns below the chair rail.
I'm going to hold off on filling the top portion for now. I may opt for something more finger friendly since I may need to pull it out from time to time. I'd like something that stays together fairly well and doesn't shed on the carpet.
Any ideas? Cotton batting?
post #2582 of 2757
Depends on what you are trying to achieve by adding insulation; bass trapping, reducing a hollow sound, etc... One thing I didn't see in the thread is where you specifically placed your acoustic treatments (the recycled) denim and my suggestion might vary based on the answer to the placement of other acoustic treatments as well as what to do with each column.
I am still working on my room treatments with OC 703 as well as some other methods using diffusion and bass traps that are not simply stacked 703. I am by NO means an expert in the field however I have a solid grasp on theory behind placement and woul dbe MORE than happy to assit in any way possible there; preferably over a good beer.
post #2583 of 2757
How do you like your LED strip lights? Based on the link you provided in an old post it looks like they probably have 3 LED's every 4 inches. I noticed some sites sell some with double the LED's.....for more $$. Do you find your lights bright enough, they sure look good in the pics.
post #2584 of 2757
I think the rule of thumb is to fill any hollow cavities with regular insulation; however, I think since the upper portion of my columns have openings for the speakers, they may be better used for other acoustic treatments such as bass traps or diffusion.
I'll get in touch with you Wes via PM or phone. Perhaps we can get together soon if our schedules permit.
post #2585 of 2757
I really like the LED strips. Much brighter than the ones I bought several years ago for 4x the price.
Mine have 3 Led's every 2 inches.
post #2586 of 2757
I'm pouring over your design specifications for your lobby bar, and I really love the design for the hidden light strip while avoiding corbels for support of the granite top. If you don't mind, I have a few questions:
1. It looks like early on, you had some little, metal brackets for support of the top -- but I don't see those in the final pictures. Did you remove those or are they "hidden" in some way?
2. If I'm adding correctly, the amount of the granite top cantilevered without support is about 8.25 inches -- is that about correct? (18" top - [8.25" wall build out + 1.5" overhang on bar side])
3. How did you build out the three end columns? It looks like a 4"x4" with an additional 2"x4" on each side. Is that correct?
post #2587 of 2757
I was hoping you didn't have the strip with 3 every 2"....now I have to decide if the cheaper ones will be bright enough confused.gif
Have you seen all the cool controllers you can add to these lights: http://www.ledwholesalers.com/store/index.php?act=viewCat&catId=94
post #2588 of 2757
I should start handing out awards to anyone that manages to get through this entire thread from start to finish. smile.gif
No need for awards, the content is reward enough.
post #2589 of 2757
Now if you can get through Logan's thread from start to finish, that would be...oh wait.
post #2590 of 2757
HEY! I can hear you, you know.
post #2591 of 2757
Hi Roknrol,
1. Yeah - I went through all this trouble of trying to add supports to the bar...must have made half a dozen trips to a variety of stores and hours trying to hide them in the design. Then the counter guy shows up and says I don't even need them. smile.gif So I took them out.
2. Yes - you have the measurements correct give or take an 1/8" here or there.
3. Two of the corners were built with just 4x4's surround by 3/4" maple. The corner at the elbow of the "L" does have an extra 2x4 on each side plus the 3/4" maple wrap. If you look back in my thread you can see the pics showing this.
Hope that helps.
post #2592 of 2757
I think my initial order through Amazon had the less expensive ones and then the more expensive ones. When they arrived they were identical. Go figure.
The packaging reads: Hitlights: 5050-60LED/M
I haven't looked at any of the controllers out there.
I seem to pretty much leave the colors the same. The only thing I really do is turn the step lights brighter when small kids or large crowds of drinking adults are present. Otherwise I have the step lights set to a very dim dark blue that is just enough to reveal where the steps are.
The ceiling I pretty much use the blue all the time.
post #2593 of 2757
Cool. Thanks.
post #2594 of 2757
post #2595 of 2757
After adding the 3D glasses rack to my Patch Panel cabinet, I thought a little more light would make sense.
So I used one of my left over LED strips to line the inside perimeter of the cabinet. It is much easier now to see.
I'm also planning to put put some OC703 in the back of the cabinet since it's in the corner. I can tell the bass is really boomy back there. Just wish I had room for 4" instead of just 2".
post #2596 of 2757
I've also noticed my electric bills rising so I'm always trying to find ways to reduce the energy usage.
I know the theater uses quite a bit but all the equipment gets powered down.
But since I have motion detectors in all the rooms and touch screens in quite a few, I've set up the screens to power down after 60 minutes of inactivity. Then whenever, someone walks in the room, the phone rings or pulls in/out of the driveway, the touch screens power back on. I'll be able to apply this to at least 3 of my touch screens around the house. The one in our great room I'll leave on all the time.
I also received some battery powered water leak alarms that I'll be placing around the house mainly because of the theater.
I'm putting one by the water heater, one by the well blader and one in the bathroom above the theater. I'll eventually add auto shutoff's too, but I just wanted something I could pop in there without a plumber involved. Just a bit more peace of mind.
post #2597 of 2757
Mario,
How much space do you have behind that for the 703? I have some good ideas to create a trap the provides good results and if you want to share Height, Width, and Depth dimensions I can tell you what I am thinking.
I used a similar space to do an Ethan Winer design bass trap that works quite well that doubles as the back of my equipment rack.
post #2598 of 2757
That's what I'm trying to figure out. In trying to determine the maximum amount of allowable overhang, according to the Marble Institute of America you can safely overhang granite that is 3cm thick up to 10" without supports. However, the cantilevered portion cannot be more than 1/3 the total width of the countertop.
Hmmm. I might just continue with a design similar to yours, with the fallback that I could add some of those "mini" supports if the counter installer insists on it.
Thanks again, Mario.
post #2599 of 2757
What color red is the wall color?
post #2600 of 2757
Mario,
Hey Wes,
I have roughly a 3" depth, by 31" wide by 48" tall behind all the wiring.
Are you thinking of using a thin 1/4" board, oc703 and then an air gap?
The challenge would be that unless I want to pull everything out, I may need to assemble it in sections behind the rack. I'll have to see how much work it would be though.
Maybe we can get together next week sometime. I've got a pretty full weekend though.
Edited by mcascio - 1/11/13 at 3:38pm
post #2601 of 2757
I think that's the information I was using but it's been a while. I remember the 1/3 rule though.
I think by me adding the extra 2x4's to create that lip, it bought me that extra 3" plus the 3/4" plywood face. The one thing I would have done differently though is put a more polished looking black backer board that the cabinet doors on the face sit on. While there isn't much showing, I should have at least sanded the face of it smooth. You can see the roughness during the day. At night, it's no biggie though.
post #2602 of 2757
The red is FR701 GOM Fabric - Claret Accent.
post #2603 of 2757
Hey Wes,
Thats the thought. The only issue is with that design I believe they call for the inside to be sealed. If not then you could do 2" OC703 with a 1" airgap.
I have a flexible schedule from a work perspective so I can move things around myself.
I will be working on my room this weekend myself...
post #2604 of 2757
They are friction fit at this point but I still need to brad nail them to suck them into the wall in places where the wood is bowed. It was challenging to get the large one out after it went in. I had to use a putty knife.
Hey Mario, I'm going through the part of your build when you were doing your fabric frames. I'm still a little way off from doing my frames but it won't be too long. I have two that will need to be removeable which I'm going to try and friction fit with velcro to help hold them (If that doesn't work I'm going to try ball and socket speaker grill parts).
Anyway for the rest I wasn't sure what to do and I noticed in the quote above you brad nailed yours. Do you see any holes from the nails or do they appear to be minor? I assume you nailed through the GOM and frame into the drywall?
post #2605 of 2757
Cool. I've been slammed this week but may try to get ahold of you before it's over if I can.
I'd have to come up with a way to air seal it if that's required.
post #2606 of 2757
I ended up not doing any brad nails to attach the frames..
I did use velcro in some places where needed. Mostly at the tops. I found rather than putting the velcro on the wall (my first attempt), it worked better by cutting a 3/4" strip x 2" long and putting it on the columns. So it grabbed the sides of the frame and keeps them from pulling out, rather than trying to grab the back of the frame.
post #2607 of 2757
So you don't get any bowing out in the middle of your frames where it connects to the crown or chair rail only? Mine should fully rest on my wainscot which ends up being 1-1/8" thick. Planning on having my frames be 1-1/4" so the Linacoustic can be just a bit off the fabric.
post #2608 of 2757
I was pretty thorough when I picked through the lumber to find the straightest I could. And I used the "select" wood. There were still some scenarios where it seemed the top would push out just a little. I didn't see any problems on the sides or bottom after a quick pass through the room. (been a while).
So I only really needed the velcro on the tops of mostly the larger pieces or wherever I noticed it pulling off the wall. It most likely happened there since it was a little tighter on the sides and the top was where there would be a little more space since gravity kicked in.
I think you'll be OK without the brad nails if you do it like mine.
I remember going through all sorts of strategies on the frames. The only downside of my install was that I have to remove some of the moulding on the sides of one column in order to take the frames out in some areas.
post #2609 of 2757
Well I’ll go with friction fit and see where the trouble is and add Velcro as needed. I am going for one 9’x4’ panel (it will have 2-3 support members) so that will be the tough one, the rest are closer to 4.5’x3.5’.
post #2610 of 2757
Sounds good. That is one large fabric panel. 3 supporting members might help to keep it straight over time too. The other obstacle is the walls...they can move in/out too. smile.gif
