Originally Posted by gbc3
It goes without saying that you've got an awesome theater. Great build thread too. I was wondering if you could comment on how well you like your HVAC for the theater, particularly cooling in our Wisconsin winters etc. The poster TV for the games is a great idea. (Unless of course you DVR the game and it ruins it)
Thanks gbc3.
I really love the zoned control. I doubt I'll need to do much cooling in the theater during the summer months because it's usually cooler on the lower level. I anticipate running the fan though on occasion to get some air flow moving and eliminate some of the humidity. I've been using the heat in there this winter. It doesn't take long to raise the temp in the room a couple degree's to take the bite out of the air. It's also very efficient. Without the zoned ability, it would be warm in some rooms and colder in others. It's nice to have the ability to just affect the rooms being used rather than the whole house.
I've heard some horror stories on this forum of people not having the ability to control climate in the room and then trying to address it afterwards...which usually ends up costing much more.
The Arzel system uses air to move it's dampers so I don't have to worry about electronic type failures. Hopefully it lasts me a long time!
I'll probably replace my battery this summer.
