AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › The Cinemar Home Theater Construction Thread
The Cinemar Home Theater Construction Thread - Page 91
post #2701 of 2754
Hey Mario, I noticed in one of your old posts that you left a 3/8" gap between your door bottom and threshold. I believe you went with one of the zero international bottoms? Is the 3/8" gap large enough to avoid any rubbing? Thx
post #2702 of 2754
I did go with the Zero International Bottoms from Soundproofing Company. My concrete floor did rise up a bit near the end of the swing of the door. So you may break out your level and verify that you don't have the same problem.
My door makes a little contact with the carpet at the end of the swing, but nothing to worry about.
You also have the variance if you door/hinges aren't perfectly level that it could swing towards the ground or the ceiling.
Lot's of moving parts, but in the end it worked out for me.
post #2703 of 2754
Originally Posted by JamesB77 View Post
Thanks for the help Mario. With your answeres and a little bit more research I think I have this figured out.
That's great to hear. Glad I could provide some assistance.
post #2704 of 2754
Originally Posted by renegade38 View Post
Mario,
How did you have your dead vent fan turn-on configured? Is it tied into the HVAC zoned controller relay output to turn on when the theater’s zone is activated, or perhaps you had a pressure sensor installed into the supply to detect the pressure change caused by an inrush of air? Other than the dead vent to the rear, are there any other returns in the room specifically for the theater’s air space? Also, it looks like that is a 6” return duct and a Fantech FG6XL fan on your dead vent, is this correct? Do you feel the 6” duct does a sufficient job of circulating air in your theater? Also, do you have dead vent fans for your supplies? Are your 2 supplies also 6”?
The Fantech turns on when the air or heat is on. My thermostat had an option to turn on FAN when Heat is on that I enabled. There's also a Vari-Speed dial to manually adjust the speed of the Fantech and then a relay that goes to the HVAC control panel. I have the Fan Speed set to HIGH all the time.
It's really awesome how fast I can get the room warmed up.
The rear dead vent that routes the air to the adjoining rec room is the only return. I used some acoustically transparent 6" vents from Soundproofing Company for all the runs in/out of the theater vents to reduce sound travel. My pics back in this thread may prove helpful. I believe that is the model I used. I'd have to look back in the thread though to be absolutely sure...been awhile.
There are 2 6" supplies into the theater. They are on the opposite side of the room as the return. So you get really good air movement and the air has to move past the projector which probably helps move the heat from that more efficiently.
There are no fans in the supplies. We did completely enclose the supplies though for soundproofing. That was actually quite a big project. Double layers of 5/8" plywood, green glue, IB-3 clips, etc. were all used to suspend them from the ceiling.
The theater is right next to the furnace room so the supplies are really close...but the sound proofing worked out great with everything we did.
You can't even hear the Dead Vent return fan unless you put your ear up to the vent.
post #2705 of 2754
Originally Posted by Moggie View Post
One idea that I employed was to have a variable speed in-line fan controlled by the pressure differential from the room to outside. The advantage of this is that it responds to different supply fan speeds and makes closing/opening the door in the air tight room much easier. More info in this post.
Cheers.
Cool Moggie. I wasn't aware of this option during my build. I usually just inhale deeply before opening the door to relieve the room pressure. wink.gif
post #2706 of 2754
Thanks for the info, Mario - very helpful!
post #2707 of 2754
You're very welcome. Let me know if you need any other information.
post #2708 of 2754
I upgraded to the Denon AVR-4520CI back in January, but never got around to posting pictures I took of it compared to my Onkyo 3008.
I really wanted to take advantage of the Denon's 11.2 capabilities.
The Denon is a bit shallower in depth. The sound is different to me than the Onkyo. It's almost a bit crisper or sharper. Not necessarily better or worse, but just sounds different.
I also wanted the ability to save the Audyssey settings to my local hard drive; however, it took about 12 tries before I finally got one that saved properly. I recently updated the firmware so maybe that will improve the reliability. The Onkyo seemed to have more options for listening modes too.
I'm still debating whether to keep the Onkyo 3008 and use it for the Rec Room area (I've got the Onkyo 609 for that space right now). I like the idea of keeping it around in case I ever need to send the Denon in for a repair, I'll have a backup ready to go.
Here are the pics.
Edited by mcascio - 3/15/13 at 7:43am
post #2709 of 2754
I'm also planning on getting the 4520 for 11.2. It might be over kill In my smaller room but the principles are still there. Are you enjoying 11.2?
post #2710 of 2754
I've been anxious to do another Audyssey calibration by bringing the 4520 into the theater near the patch panel. This will eliminate the long cable run for the Audyssey mic that I use to do the calibrations.
Some posts I read say the extra long mic run may make a small difference.
I haven't had time to watch too many movies in there since getting the Denon.
post #2711 of 2754
Are you going to sell the Onkyo?
post #2712 of 2754
I'd entertain some offers via PM...but I'll probably end up keeping it. Although the Onkyo 3008 is not in use at the moment so if I sell it, now's a good time.
My upstairs great room has an older flagship Yamaha RX-V1 if anyone is interested.
I'd like to move the Onkyo 3008 into my REC ROOM TV seating area, then move my Onkyo 609 from the rec room upstairs to the great room to replace my Yamaha RX-V1.
So I'd prefer to sell my Yamaha RX-V1.
post #2713 of 2754
Hi Mario,
Did not know if you saw this. The OP isn't getting much help.
http://www.avsforum.com/t/1466668/main-lobby-controller-question.
post #2714 of 2754
Originally Posted by dormie1360 View Post
Hi Mario,
Thanks. I didn't see that post!
post #2715 of 2754
Great theater Mario! One of my favorites
I've recently finished building my own theater and have a similarly sized 2.35 screen as you do. How do you like the Panny? Is it bright enough for the 136" scope movies? How about 3D? What mode are you running it in? I'm considering this PJ for the auto zoom feature and brighter modes.
Also a few pages back there was a question about setting up the auto zoom when the projector was mounted above the screen. Any more feedback concerning that?
post #2716 of 2754
Hi Gomdaf,
Thanks for the compliments and congrats on the completion of your theater.
I'm really enjoying the Panasonic AE-8000U. I find that it's bright enough. Although, as I've always said, you'll never know the difference unless you have another projector to compare it too. In my case, I had the AE-4000U which I thought was fine too. This one definitely brightens up the room much more. There have been some scenes where the screen goes all white and it's almost blinding.
My projector sits even with the top of the screen. In 4x3 mode, I have my LENS CONTROL set to a V-Position and H-Position of 0. Assuming my projector was above the screen, I can still lower the image even further. In 2.35 scope movies, my vertical position is set to -29. So I still have more room to shift it down if it was above the screen.
3D could be a little brighter, but the only reason I say that, is because I can compare it to the 2D image which is obviously always going to be brighter than the 3D image. So in a perfect world, they would be equal in brightness.
Because of the fan noise though, I opt to run the Panny in eco mode all the time. I could gain even more brightness by taking it out of ECO mode.
post #2717 of 2754
Mario,
Just wanted to spend my first post to thank you for your efforts in documenting every step of your build. You've gotten a lot of positive feedback from a ton of people. My project will begin soon. Stay tuned for my build.
Joe
post #2718 of 2754
Originally Posted by cRock HT View Post
Mario,
Joe
Hey Joe.
I'm always honored to be the first post by new AVSers. I really appreciate it. Send me a PM when your thread begins so I can follow along.
post #2719 of 2754
My sump alarm has gone off twice in the past few weeks. The float didn't seem to be obstructed and I didn't see anything floating in the sump so it leads me to believe my main sump may be failing. If I pushed the vertical float down and then back up again it fired just fine.
I've had this Little Giant for about 3 years now. Fortunately I'm still under warranty. Little Giant is sending out replacement parts to see if that resolves the problem the failing switch. We've had a lot of rain lately and my sump has been running quite a bit so it's been getting worked out for sure.
With the warmer weather and a need to have a better backup plan in place...I finally routed the backup sump drain underground and away from the house. Thanks to forum members for giving me ideas on how the parts to do this.
post #2720 of 2754
Fix it. FIX IT NOW. STOP WHATEVER YOU ARE DOING AND FIX IT NOW!
I'm just saying, you do not want the consequences of NOT fixing it. There's really no telling what's going on with the watertable below ground, that you can't see. Your water table may not see the effects of a hard rain for two or three days to run from where ever it runs from. Just because it stopped raining, doesn't mean the water isn't still rising!
We haven't had a hard rain for about a week and my pump is STILL running pretty regularly. Let me tell you, I keep a close eye on the spring-fed pond across the street! Some day I need to actually measure the waterline against my basement floor height.
post #2721 of 2754
Yup. I'm with ya. It usually takes 3 - 4 hours after heavy rain before the sump starts running frequently. My sump pretty much runs daily through-out the year unless we really hit a dry spell.
I tested my backup sump and it's working so I still have a backup in place.
I probably should have checked to see how long shipping of the replacement part is going to take from Little Giant. I'm tempted to buy another sump pump to have on hand, but the warranty starts the day you buy it. Ideally you have two main sumps the same so you have just swap them easily without having to adjust pipe depth and recut anything. It looks like the one I have though is already discontinued.
post #2722 of 2754
Always seems like there's yet one more ditch to dig, huh... : )
post #2723 of 2754
Yeah - I guess it's better to dig this ditch than dig out the theater though. smile.gif
I'm getting a little splashing as the water comes out of the 1.5" into the 5" right angle. I have the 1.5" centered to the 5" but I'm wondering if I move the 5" so the water is gushing right into the angle part it will prevent the splashing. Looks like I'm going to have to undig the pipe again so I can slide it a little.
post #2724 of 2754
I just purchased one of these for my sump - worth the additional piece of mind of never having the float "stuck" IMO:
http://www.washerwatcher.com/sump_controller.htm
post #2725 of 2754
Interesting. Did you get it setup yet?
Did you have to put the ground in?
The only downside I see is actually testing the sump to make sure it's working. It doesn't appear you can do a test trigger...or can you?
post #2726 of 2754
Yes, I have it installed now and running great. In my case the sump naturally runs about once a day, so to test it all I needed to do was ... wait smile.gif Otherwise you would need to pour water into the pit to test it.
I'm not sure what you mean by having to put the ground in?
Edited by kromkamp - 5/1/13 at 6:53am
post #2727 of 2754
http://www.electronichouse.com/article/theater_shakes_with_112_surround_sound_d-box_motion_simulator
A big congrats to you Mario!! Very well deserved!! I must say your HT handily beats many professional installation as agreed on their Gold award!! wink.gif
post #2728 of 2754
It's about damn time!
post #2729 of 2754
A well-deserved CONGRATULATIONS on the nice article in this national publication. It goes without saying that you are an inspiration to all those with the willingness and drive to make the most out of the DIY theater building experience!
post #2730 of 2754
