Mario,
Triad speakers are very highly regarded but as I said earlier it is very subjective. I would recommend that if you decide to consider replacing your M&Ks that you listen to several brands first.
I do think you would be happier with an AT screen, even if you have to sacrifice a little in screen size. My advice would be to build the screen as big as you can and add masking panels if it is too big. The difference in price isn't as much as having to buy two screens if the first one is too small!
Placing the speakers below your screen would be a bad move IMO. Since the screen floor is already so low the sound would have a difficult time reaching the back row.
