I just added a Sherbourn 5/1500A to my system. I'm now having a humming problem, but I'm not sure if its a problem with my electrical or the amp. Let me explain what's happening...
I have two lamps on different outlets, each are also on a different outlet as the Sherbourn. When I put either of these two lamps on the lowest setting (these lamps have two positions) I hear a loud hum from the Sherbourn. If I turn the lamps to the second setting the hum stops. I have a third lamp that is on the same outlet as the Monster HTS-3500 to which the Sherbourn is connected and no matter which setting it is on there is no hum from the Sherbourn. So, my question is, is this a problem with the Sherbourn or my electrical? How can I get rid of the hum if it is my elctrical and not the Sherbourn?
What makes this weirder is that when I was testing the Sherbourn I noticed the hum. While I was testing it the Sherbourn was plugged directly into the wall. It was then that I realized it only hummed when one of the lamps was on low. I then tried plugging the Sherbourn into the HTS-3500 and the hum went away no matter what the lamps were set at. I thought that was the end of it... but, when I put the Sherbourn in my rack, the humming came back even though it was connected in the same way.
Ok, and one final oddity... now my TV speakers hum when playing through my Tivo (cable) and my satellite Tivo. This never happened before. The only difference is the Sherbourn (I did disconnect everything when putting the Sherbourn in, but reconnected it all in the same way... I realize something may have happened when doing this, but I double and triple checked all connections). Just to see if it was the Sherbourn causing the problem, I disconnected the Sherbourn from the HTS-3500 so it was plugged into nothing. The TV speakers still hum. Why would this just start?!?!?! It has nothing to do with the Sherbourn since it wasn't plugged into anything.
Thanks for any help!!
Jeff
Jeff
