Hmmm, but isn't this just another custom resolution that is freely programmable anyway in the Radiance ? I have used or tried 1920x810/817/820/880 with both 48 and 72Hz and it was all very easy to program once I set up excel to calculate the pixel clocks for me - the only downside was that I could only use the Radiance with 8 different resolutions
Originally Posted by jrp
The RadianceXD/XE/XS 148.5 MHz clock limit comes from our choosen FPGA and how fast we were able to get the logic to run. We worked hard to get to 148.5 MHz, and this is good for digital TVs/projectors. The FPGA has a small speed variation over process, voltage and temperature. We are putting in a test command that allows higher frequencies for Craig, but I don't think he will get a lot more out of his unit. We will have to consider whether it is worth adding higher clock in the timing menu to our general releases.
Thanks for the clarification, it seems that 165+ Mhz clocks or preferably more seem rather far off for a processor that just barely manages to go up to 148.5 MHz.
I liked it when I could increase the total horizontal pixels for 1920 x 1080 59.94 Hz to 2280 or even 2360 with the Vision line, that worked better for most CRT projectors and only requires a pixel clock of up to 159 MHz.
We put it in as soon as we had some time to do so.
