Hello all,
I am wondering a few things about room within room construction. I am sure all this information is already here somewhere, but unfortunately its very difficult to search for! (need to come up with a more search friendly name than "room within room"
In my situation I have a basement room where all 4 walls are foundation wall, so I would build 4 stud walls spaced an inch away from the foundation walls and 1 inch away from the existing structural ceiling joists, then run new joists in between supported by the stud walls only.
My questions are:
1)I'm concerned about structural stability? If nothing is anchored to the existing structure it seems to me like it would be 'flimsy'? I'm also concerned that local contractors and building inspectors would be confused by this - how to get it passed?
2)If I use spray foam (closed cell) to insulate the foundation walls, this will almost certainly short circuit the 1" gap from the stud walls. Is this going to completely negate the decoupling? (I am reluctant to use anything but foam to insulate for moisture and other practical reasons)
3)are 2x4's (on a 14' span) okay for the new ceiling joists? Since they will only be supporting 2 layers of drywall and insulation. Or would you go 2x6s?
4)Are there any detailed construction plans posted here that I could pore over?
Andy K.
)In my situation I have a basement room where all 4 walls are foundation wall, so I would build 4 stud walls spaced an inch away from the foundation walls and 1 inch away from the existing structural ceiling joists, then run new joists in between supported by the stud walls only.
My questions are:
Andy K.
