AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Denon 3808 Upscaling
post #1 of 5
I need to purchase a Blue/ray player hoping you guys can help me out.
IF I purchase the Oppo 83 it is known for its ability to upscale DVD's. Which is nice cause we still have a ton of regular Dvd's.
question: If I run the HDMI from the Oppo into my Denon 3808 will the Receiver try to upscale the video as it leaves the receiver and goes into my LCD? I was told only when the signal is 1080P will the Denon receiver not touch the signal from the DVD/Blue Ray Player? Is this correct?
I'm a bit of a newbie and need some help to make a smart purchase of my blue/ray player.
Thank you in advance!
post #2 of 5
You can turn the i/p Scaler OFF in the 3808 so it doesn't do any video processing if you simply want it to pass through the video.
post #3 of 5
Does it show how to do it in the manual? Have a hard time reading that thing. Any experience with the Oppo 83 vs lets say the Pioneer BDp-320 or the LG390? I do have a lot of regular DVD's.
post #4 of 5
Check p. 30 in your manual, although the default is AtoH which wouldn't do any processing to HDMI input. No personal experience with any of them, although the Oppo 83 comes highly recommended from posters in the Denon threads.
post #5 of 5
Since I'm currently using my Xbox 360 to play Dvd's and it is not doing any up-scaling, I believe my display is doing the up-scaling correct?
Again display is a Samsung ln55a950.
Does anyone know if the Oppo bdp-83 would do a better job at up-scaling then my LCd does? Or would the LG 390 do as good of a job as my LCD?
Thank you!
