I asked this in the Official Harmony One thread, and saw other Jukebox issues, but not quite my issue.
I have the Sony CDP-CX90es and a CDP-CX230 hooked up into it via the a link. My Sony remote is set to the number "2" on the top.
When programming my Harmony, it recognizes the name CDP-CX90es. It also asks for me to use my old remote to program, though. So I hit power, play, 1, and enter. It says its ready.
When using the Harmony, I can turn the juke box on and off, and hit play and use the up and down channel function to change discs.
I cannot, however, use the 4 way directional keys, or correctly assign the "sort" function to a key. I tried using the old remote and directly assigning these button presses, but to no avail. I do notice that it takes multiple presses of my old remote for it to be seen though. I change batteries and had a similar issue.
Am I missing something? or Does the Harmony not like my CD player? I would imagine that since the system is in the data bank that it should work, but then I am confused why it asks for me to input any commands.
Should I retry programming my harmony? Should I move the switch to "1", even though I use 2 as directed by Sony? Or will logitech customer support be helpful?
Any help appreciated. Thanks.
