post #1 of 1
It's time to upgrade to 1080P from my Sanyo Z2 and Oppo 971
Need a new PJ and DVD player and I'm interested in your real world advice/experience on what to buy.
Here are some details:
1. What is the budget for the Front Projector? **($5K including DVD and PJ calibration)**
2. What are the Room Dimensions? **(24L x 14W - 11 feet to screen from seating)**
3. Ceiling Mount / Self Mount / Table Mount? **(Ceiling)**
4. Screen Size Desired? **(Have/using 100" Carada 1.0 Gain)**
5. Screen Material Desired?
6. Will the projector be placed within / above / below the Screen area? (This will determine how much Lens Shift or offset is needed.) **(Above)**
7. Can you get the room total light controlled?**(Total control)**
As I mentioned I want to match a DVD player to the PJ and have the PJ calibrated so suggestions on the DVD would be appreciated as well.
Thanks in advance and let me know if I can provide any other info.
