shielded hdmi ?
post #1 of 6
so i have installed my screen, set up my speakers, tonight i install projector.....but i have a ?, i have a electrician coming to put in the outlet next to my projector mount and i was going to have him run the HDMI cable at the same time BUT i read that it could cause interference with them running side by side, i bought this HDMI cable from monoprice
HDMI Tin-Plated Copper CL2 Rated (for In-Wall Installation) Cable (24AWG) - 45ft (Gold Plated Connectors)
is this shielded enough to run side by side????
tia
post #2 of 6
I think you will be fine, just have your electrician put one on either side of the joists or give them around 5-6 inches of space between them. Your HDMI cable is nothing more than a fat ethernet cable, and I have allot of that ran through my house with no issues where I have it running parallel with my in wall wiring. Like I said, just put a few inches of space between them and you should be fine.
post #3 of 6
As stated above you will be fine. HDMI is a balanced digital signal and is highly immune to residential levels of EMI/RFI interfierence. Plus all certified HDMI cables are overall shielded as well.
post #4 of 6
they will be on the same side of the joist, but i can get some inches in between them
post #5 of 6
Have your electrician run conduit if the walls/ceiling are still open.
post #6 of 6
it will be tough, to run the wire we have to go up through a drop ceiling and run wires over a bathroom between joists, it would be touch to run pvc or something like that unless we use small 2.5' sections, unless we used plastic flexible tubing
