AVS › AVS Forum › Video Components › Home Theater Computers › HTPC - Mac Chat › Skipping the reciever?
post #1 of 3
I have a Macmini running wirelessly with a 750 gig HD hooked directly all mounted behind the 32"Hdtv.
I am wondering if there is a way to connect the digital audio out(3.5mm TOSlink) to a pre amp 8 channel splitter. THis way I could use powered speakers and skip the amp.
would I get surround sound, or just a 7.1 stereo?
should i just build a receiver closet hidden somewhere and use redeye with my ipod touch.
I am basically trying to clean up the living room. I want the tv on the wall with everything else gone..... except of course a few speakers (6-8 speakers) hidden around the room.
Or a small foot print digital receiver closer to the size of my mac mini (i know dreaming, based on heat dispurtion)
I can either get rid of my Onkyo receiver, or hide it. What are my options peolpe. I need help.
Thanks Late247
post #2 of 3
If your pre-amp is doing the decoding, you can get all the surround codecs with it (Dolby Digital, DTS). However, pre-amps are pretty big too. I don't think you can make it tiny. There are some digital amplifiers that are pretty small.
post #3 of 3
my tv is mounted on a brick wall with nowhere to hide anything, other than behind the tv itself. If the mac processes the digital (or just passes on the 5.1)signal , and the amplification is done by the powered speakers, isn't there a device to simply separate the different channels?
Does this make sense, or am i going about this the long way?
  Back to Forum: HTPC - Mac Chat
