Originally Posted by
hd_newbie
Some generalizations also happen to be facts. Law of gravity is a generalization, but that doesn't make it any less valid.
Laugh. The LAW of gravity is NOT a generalization. And it doesn't depend upon the room, either.
hd_newbie
Can you please give me an example of when 40Hz cross-over will provide more accurate sound reproduction then? I can think of 4 scenarios:
1) The subwoofer in this particular situation is not up to the task of handling upper bass accurately.
How about the subwoofer in question is more than up to the task of handling the upper bass but the upper bass is STILL handled more accurately by the speakers than the sub in this particular room, in the speakers' and sub's (or subs') particular locations? Is that so hard to imagine?
hd_newbie
2) Subwoofer in this particular set up is not built competently, so speakers in fact sound better.
How about the subwoofer is built even more than competently but the speakers in question STILL sound better than the sub in the 40Hz to 80Hz range in the speakers' and sub's (or subs') particular locations? Is that impossible to fathom?
hd_newbie
3) Subwoofer in this particular set up is not calibrated correctly and does not blend in properly with the speakers.
How about 40Hz crossover provides much better integration and FR than an 80Hz crossover in a particular room with the speakers and sub(s) in question? I know you can wrap your head around that.
hd_newbie
4) Subwoofer is localizable due to room related acoustical problems.
How about subwoofer is not localizable even with a 120Hz crossover but a 40Hz crossover STILL sounds better, measures better, is more accurate, etc. than an 80Hz crossover setting? Why is that so unbelievable?
You're not listening to what I am saying. It is very possible that a particular setup might sound best with an 80Hz crossover in one setting yet sound best with a 40Hz crossover in a completely different setting. Or be more accurate. Or measure best. Or whatever your criteria for "best" might be. Yes, if you could measure the "accuracy", it is very possible that a particular setup might be most accurate with an 80Hz crossover in one room yet a 40Hz crossover in another.
Do you REALLY disagree with that?
If someone wants to throw their stuff in a room and just automatically set the crossover to 80Hz based upon generalizations, that is just fine. But some people might want to actually verify which crossover setting provides them with the best experience by whatever their criteria or means might be for evaluating that. Be it their ears or measurments (which might not necessarily agree).
hd_newbie
Producing the bass via speakers is less than an ideal choice due to following reasons:
1. The ideal placement for the 2 front speakers is hardly ever the ideal placement for the subwoofer. It is almost always a good idea to separate the bass from the speakers. This will provide superior placement flexibility in overcoming room modes.
2. Speakers have cabinet size limitations and subwoofers don't. Thus, it is very difficult for a speaker to produce the same quality bass as a competently built subwoofer. $100K + speakers is not exception to this.
I (we) know the benefits to be had by reproducing bass at a subwoofer instead of at speakers. And there are others besides what you list.
But making a blanket statement that with sub-40Hz capable towers and, yes, an equally capable sub, an 80Hz crossover setting is "better" than a 40Hz crossover setting is being a bit silly, don't you think? You just can't make that sort of generalization.
hd_newbie
To summarize, in my opinion 2-channel sound reproduction without a subwoofer is one of many audiophile myths. I can't think of any scientifically-backed reason why someone would prefer a full sized tower with no subwoofer to a high end satellite-sub combo with decent sized drivers.
We're not discussing 2 channel only versus 2 channel supplemented with sub.
