Just purchased this set yesterday at cosco cant seem to get the picture to look as good as it was at cosco.With you that either has owened this model or own it now,what are your settings that allow you to have a great picture?
when i first got my set i used the free disc on here to calibrate my set. make sure your in movie mode and use warm 2 for your color temp. i bought an eye one display 2 to try and fully calibrate the set and its defiantly worth it. youll see details you've never seen before. the only thing that seems to be wrong with the set is that the blues are overly saturated. heres a review of the tv. in the calibration section of their review it says to use warm3 but i get better results with warm 2. also in the calibration section it says to boost the backlight up to 10 but i think they calibrated in a light room because when i calibrated my set in the dark the best results came from the backlight being at 3. hope this helped, enjoy your tv!
Thanks a lot that is exactly what I was looking for.Were do you get that free disc to calibrate your t.v.also direct tv is coming monday to hook the set up what are the best cabels to get for this set for optimum viewing.
