I have the following equipment:
Denon 2807
2 x HSU ULS-15s(dualdrive)
Emotiva XPA-5 AMP
4 x Klipsrch RF-82
1 x Klipsch RC-64
When I calibrate my reciever using the microphone it sets the speakers all to large and the XO pretty low.
I hear many people say that xovers should be set to 80 with speakers all set to small no matter how good your speakers are. Whats the best way to handle this? Should I just skip the EQ calibration and calibrate with my SPL meter instead setting everything to small and 80hz XO or shoulud I let my reciever calibrate it all automatically?
Denon 2807
Emotiva XPA-5 AMP
4 x Klipsrch RF-82
1 x Klipsch RC-64
This is definitely not appropriate and Chris has recently gotten them to change their settings. Denon has gone to 40 Hz, Onkyo to 60 Hz. In any event, Chris K. has long suggested that, if the speakers are set to "Large" by the receiver, they should be reset to "Small" by the user, and the first crossover point that comes up is the recommended crossover.
) I used to wonder this, too, and my queries were answered in the Audyssey thread. After you raise the crossover setting (or even apply it, anew) you do not have to re-run Audyssey. Audyssey remembers the filters necessary for each individual speakers' (and subs') full range of response no matter what sort of cutoff setting is applied to any particular channel.
