AVS › AVS Forum › Video Components › Cable, Digital Cable - Non-HDTV › QIP6400-2 Optical Ouput to Sherwood Amp SUPER LOUD at Volume 1
post #1 of 2
OK, not sure what's up, did research and can't find similar topic.
I hooked up my FiOS QIP6400-2 optical output (using appropiate fiber cable) to my Sherwood RD-6500 optical input. In-auto was selected on Sherwood, and audio stream from FiOS box/programming was 5.1. I turned receiver all the way to 0 (lowest setting doesn't go negative) and sound was mute.
I turn the dial to "1" and BLAMO the sound is SOOOO FKN loud it's un real and doesn't sound right. Only part of the stream (i.e. no bass or front end noise people talking) but either the theme music or crowd (e.g. football game on and I barely hear announcers but crowd is SUPER LOUD) is audible.
In troubleshooting I used the same cable (after cleaning it with my green clev top) and ran PS3. SOUNDED BEAUTIFUL.
Could it be the opt out on the QIP is fkd?
Thanks In Advance.
Best,
Sonny
post #2 of 2
Either a setting or the optical out on the QIP has a serious problem.
  Back to Forum: Cable, Digital Cable - Non-HDTV
