Just one driver per enclosure, but it is probably best to use these in pairs. The Tang Band W6-1139 also works according to the model, but not quite as well as the Anarchy. Total volume is closer to 3 cubic feet than I wanted, but there is 1/2 a cubic foot of wood inside the cabinet as dividers for 13.5 feet of tapped horn all folded up in there. With 1/2" material it is 20.125" X 30" X 8.25" external, and there is zero wasted space inside.
I will post the modeled predictions and comparisons to the actual measurements when I am done. If worthy, rest assured I'll post drawings, plans, details, and a cutlist so that anyone else can play along at home. If my measurements are not what I expected, I will post what I did and what I found so that we can all work together and try to figure out what went wrong so that others do not make the same mistakes.
I have not posted much about this yet because I do not consider my designs done until they are built, measured, and proven. I don't want to waste other people's time with something that may not work.
