I'm guessing you have seen Patrick Bateman's design philosophy then on tapered horns then.
http://www.diyaudio.com/forums/subwo...ml#post2215852
Using two horns one as a low horn(shiva-x) and then the high horn(MCM 8") is pretty interesting. But ever design has a set of draw backs for ever advantage that it gives and you would have to figure out how to crossover the two subs.
