Happy new year :-)
My first project this year will be builing my first HTPC that fits into our livingroom. It has to be a beautiful, very quiet setup (preferably passive cooled) and powersaving.
I need some help choosing the right case for that purpose. If you could give me some words to help me make that choice easier, I would be very thankful.
The HTPC should of course be able to play HD movies, blu-ray and music. I have an external USB DAC from Pro-Ject (using it together with my Naim amplifier), so I have no soundcard requirements.
The biggest limitation to choosing the case, is the size of the rack it has to fit in, including it's cooling abilities:
Requirement #1 - Rack size: 440x150x330mm (WxHxD). The height is not that important, as I can adjust my rack.
It would be no problem to get a case in that size using a Mini-ITX motherboard (maybe in an "HFX micro" so I also get passive cooling). But I altso need to fit in two TV tuner cards:
Requirement #2 - 2x PCI TV Tuner card. One might be enough, but it would be nice to have two PCI slots anyway for future possible use.
The "Silverstone LC04" case fits into my rack, and according to the specification the number of expansion slots available is: "2 (includes 1 x PCI riser card)". So fitting the two tuner cards should not be a problem.
Theres also the "Silverstone LC02" case, but it only allows for one PCI card (with riser). Theres also only room for a slim Blu-ray drive.
The last case I've been looking at is the "HFX micro". It has one big advantage and thats the passive cooling. However it only fits an Mini-ITX and theres no room for PCI cards. The PCI cards I can live without by using an external TV tuner card (TerraTec H7).
All the above cases should be using a motherboard with integrated graphics (has to have DVI/HDMI out), except for the LC02 which also has a PCI-E raiser cards. The "HFX micro" case should be the last possible solution because it's the most expensive and the hardest case to build in.
So at the moment I'm most hooked on the LC04 case, because it has a nice size that easily fits my rack. I don't think it has a PCI-E raiser card, so onboard graphic chip is a must here.
My biggest concern here is it's cooling abilities. I'm very unsure about what motherboard and CPU to fit in it to get the most quiet HTPC possible. What do you think of the LC04 case? Is it a good HTPC case for a quiet system? And what components (mainly motherboard and cpu) would you pick to the LC04 case? I do not need a power horse. Only one that can play blu-ray and HD movies.
Or can you recommend other cases that would suit me better?
Looking forward to hear your thoughts and suggestions. Thanks in advance :-)
