AVS › AVS Forum › Industry Area › HDMI Q&A - The One Connector World › HDMI-DVI picture interference
post #1 of 4
I have some annoying picture interference problems when connecting to my plasma and it's only from this source i have this problem with, all other HDMI equipment work good.
If you look at the picture i have attached you will see, anyone seen anything like that before and what's causing it? i have even tried different cables and the same result.
Please help.
post #2 of 4
what is this source? It may be the source is screwed up somehow?
post #3 of 4
It's a Linux based open source satellite receiver, with the official software loaded i get the interference above, if i however load 3rd part software developed for it i get no interference.
The difference is that 3rd part software has HDCP disabled, i can not use 3rd part software for other reasons so it doesn't solve the problem for me.
I am still investigating how to solve this and have emailed the manufacturer about this problem.
post #4 of 4
sounds like it's whatever's going on in the box, software etc. Doesn't sound like a TV problem at all, or cabling.
