AVS › AVS Forum › Display Devices › CRT Projectors › Blanking Question
Blanking Question
post #1 of 6
Sony 1272- On the left side of my screen, I need to fill in about a inch of vertical picture. I tried the blanking button, but it won't fill it in.
How can I move the picture over a inch or so to the left?
post #2 of 6
Raster needs to shift his Raster
Athanasios
post #3 of 6
On my G70 there is a RGB Image Shift button on the remote. With this you can move the image to the left, right, top or bottom. Alternatively you could increase the image size and use the blanking feature to cut off excess screen images on the other other sides. Maybe this helped you a bit.
post #4 of 6
if you have 4-12(x-1)
would the simplification be:
4-12x-12
4-12x+12
so basically wat i mean is does the minus after the four affect the distributing...
i kno its simple but im blanking!
post #5 of 6
Raster
Are you still using Svideo as the preferred mode of feeding your beast "HD" signals???
Martin
post #6 of 6
raster, do you think you could blanking leave?
  Back to Forum: CRT Projectors
