post #61 of 61
Originally Posted by BPlayer View Post
Have you ready the excellent thread on selecting a remote:
http://www.avsforum.com/t/1318737/remote-control-faq-buyers-guide-and-programming-thread
A Harmony remote would be ideal, BUT it requires some customization for your device configuration, and a new one will be above your price range. If you are prepared to put the effort in a used model from eBay (with a guarantee) will get you going. Some models to consider are the 650, 680, 700, and Harmony One.
Any of them will be able to send Audyssey setup commands, but this is typically a one-time or very infrequent function so that is a non issue.
