post #1 of 1
Hi...i`m not sure what is happening here. Since i got my new set of 5.1's (Samsung HT-TXQ120) a lot of sound settings have changed.
What i`ve gathered so far is (using optical input/output)
1. When you want DTS, you have to change the sound device in W7 to SPDIF and check SPDIF in ac3filter)
2. When it DTS, you cannot listen to multiple streams at once
What went wrong is:
- Winamp was playing sound out of all 5 speakers but after a while it just uses the front and center
- And the actual issue is with ac3.. it sometimes does not load the ac3filter like displayed below. Anyone know why?
