AVS › AVS Forum › Audio › DIY Speakers and Subs › My first TC SOUNDS DIY sub! ***LOTS OF PICTURES***
My first TC SOUNDS DIY sub! ***LOTS OF PICTURES*** - Page 3
post #61 of 83
Originally Posted by maintrain View Post
On the webpage in that link in the first post, the author refers to an excel spreadsheet he used to calculate the mass needed for his passives. Maybe it will help someone else who's trying to figure this out.
http://www.danmarx.org/audioinnovation/passive.xls
@oachalon
post #62 of 83
maintrain, thanks for the help.
post #63 of 83
Originally Posted by oachalon View Post
does anybody have a passive radiator calculator online, im too lazy to calculate by hand right now. All the links i found were dead. AE speakers used to have one but it looks like the link is dead as well.
I just use WinISD Pro, they have a PR option.
post #64 of 83
so with a 6-6.5 cubic ft enclosure i would want to add about 1550g to the exodus passive radiators. that will give me 1850g each and tuning of around 17-18hz.
post #65 of 83
Nice job, good exicution!
post #66 of 83
I haven't run the numbers but that sounds about right.
post #67 of 83
maintrain, a crossover of 60hz or below would work great with the TC 3k sub. Measure the sub in the PR box and see what you get, if your response is great to 80hz, that's where I would cross it at.
post #68 of 83
Holy &%$!
I cannot believe how good this thing sounds! Terminator Salvation soundtrack is ridiculous and this sub is LOUD! I can't turn the ep-2500 past 1/4 gain with out it completely overpowering all the other speakers. My wife was caught completely off guard during one of the action sequences and nearly jumped off the sofa! Back to the movie!
post #69 of 83
Holy &%$!
Sweet!
Glad you have the results you desire. Nice work!
post #70 of 83
maintrain, what crossover did you use for the TC 3K? Did you do any frequency measurements? Yes, the TC 3k sub can go low and hits hard in the low bass when called upon.
post #71 of 83
I am really happy to hear the performance matches the look of your great sub.
What sub were you using before?
post #72 of 83
It's crossed @ 50hz but I haven't had a chance to do any measurements yet.
Audiosource SWfifteen. Doesn't even come close to sounding like this!
I now have a little hum coming from the audiobuddy pre-amp. Hum disappears when I bypass the pre-amp but I lose a lot of volume from the sub without it. I've read threads about grounding issues using a rca to xlr adapter. This is the one I'm using: http://www.parts-express.com/pe/show...number=240-438 . Would I be better off using a cheap ground loop isolator or running a 1/4 to rca adapter on the high impedance input?
post #73 of 83
Read this page and try building a cable according to the chart, #17:
http://www.rane.com/note110.html
Too many threads here on hum already.....give it a shot, it may cure the problem.
Cable_A.pdf 33.9052734375k . file
post #74 of 83
Hey Marcus,
Why would you use the audiobuddy pre-amp if you only have the gain turned up 1/4 of the way on the amp? You can rub the gain all the way up on your amp, I do and control the volume from either my pre-pro or Velodybe SMS-1.
You could try one of these to connect you receiver to the sub-amp:
Just some suggestions as I noticed you commented on having the gain only 1/4 up on your amp before when watching a movie.
post #75 of 83
Just wanted to say very nice build man, it looks and I'm sure sounds awesome.
post #76 of 83
Yeah I read about that. I ended up buying a Sampson s-convert and that solved all my hum problems and gave me a stronger signal into the amp. I picked it over the art cleanbox seeing that I wouldn't have to mod it. It's working perfectly.
Hey Marcus,
I'm ditching the audio buddy. Truth is, I couldn't turn it up over 1/4 without picking up noise from the sat antenna cable. I didn't get noise when testing at work. All is well using the Sampson S-Convert and I'm using the avr sub volume control.
Thanks Reaper. I'm enjoying it more everyday.
post #77 of 83
Glad it worked out for you, mt. Funny how everyone's mileage varies......I had to ditch my S-Convert, ends up it was amplifying all AC switching noises in my house beyond comfort level as described in my earlier thread:
http://www.avsforum.com/avs-vb/showt...969&highlight=
I ended up getting a MIC2200 to provide boost/eq....truth be told, I could have gotten by without it and am running everything at 0db level, no boost. My older Onkyo AVR provides enough output to the EP2500 as long as I keep my audio signal separate from any chassis ground (as in cable config #17). With chassis connected on the EP input side I get hum up the wazoo and a big signal loss. When I hook up my Yamaha powered mixer (unbalanced output) to the EP with no special cables (chassis tied to signal common via adapters) it works great. Go figure, you never know when interfacing "home" with "pro", trial and error is necessary.
BTW, great build!
post #78 of 83
minor update. i've changed amps. went from the ep2500 to and yamaha p7000s. I'v read threads that state the yamaha pxxxxs amps don't perform very well @ low freq but i am experiencing the opposite. the yamaha is giving me better performance <30hz and i truly do NOT miss that fan noise! Another thing, it's running 4ohms bridged and doesn't seem to have any problems running that load. I plan on spending more time with it this evening.
post #79 of 83
Amazing build quality...love me some TC Sounds
post #80 of 83
I can't believe it has been on over a year since I updated this page. I have a new video to post. Check it out: http://www.youtube.com/watch?v=dfu_B7kTC-o
post #81 of 83
I admire your work! Excellent stuff. Inspires me to back into DIY!
post #82 of 83
Can you play this on your sub and tell me what you think?
http://www.youtube.com/watch?v=ZgcDxm1HI60
Either way awesome sub.
post #83 of 83
I am jealous of those passive radiators. This sub looks very nice. I just have a couple questions. What made you decide to notch the wood for the binding posts? Also why not make the TC Sounds Logo straight across? Do you have any REW plots of the frequency response? Anyways, very nice sub.
