I have a panny pt-ax200 with just over 3000 hrs on it, got the "warning" to replace the bulb at around 2300 hrs, so i reset it and we are now at just over 700 more hours (3000 total) so I am getting nervous and want to have a replacement in hand vs waiting for it after it finally does die
Is it "ok" to just keep using the 3000 hr bulb here, so far zero issues so figured i was ok if i just keep the vents clean and clear and heck it still "works" so unless I am doing damage to it I figure I would just go till it doesn't light up again.
Once the bulb does die do you get some sorta beep or anything to let you know it's your bulb (not the projector).
Should I go with a bulb only or complete housing?
Also should I go with an off brand or a panny only bulb?
Hoping by now other users have got some real user experience to share on changing the bulb or complete housing and or if aftermarket bulbs (which appear to be a great $$ saver) are decent quality and or if they last as long etc.
Thanks for any input,
Bill
Bill
