I'll try to provide as much info as possible the first time so I can get the best answer up front, and not waste anyone's time.
I have a home built server running WHS, plugged into a Gigabit LAN that is wired throughout my home. I'm looking to build (or buy) a box that I can place in my living room (only location needed) to do the following:
-Stream DivX and 1080P mkv's from my WHS box
-Stream shows from the web (Networks: Bravo, ABC Family, MTV, Food Network, ABC, NBC, CBS are essentials)
-Stream Netflix and Hulu
-Play blu-ray (not essential, but would be nice)
-Would connect via ethernet to my Gigabit LAN
I will connect the living room box to my Samsung 1080P LCD TV, as well as my AV receiver. The AV receiver can accept audio and video over HDMI, and pass through the signal to the TV. Size should be relatively small. Not looking to build a tower, I want it to fit in my entertainment center with my other components. Mini ITX or Micro ATX a plus.
I am looking for advice on hardware. Would a Zotac ION board cut it? If not, what CPU/GPU combo would work best? New Dell Zino? Mac Mini? What about OTA for my local CBS, ABC, and NBC channels? I don't have an antenna, but am not opposed to setting one up if it makes sense.
Also, looking for advice on software. XBMC? Boxee? Am not opposed to running in Linux for hardware acceleration of HD content via VDPAU.
Budget around $500 or so, but somewhat flexible. Looking to ditch satellite and save money, so I figure I'll make up that $500 within 6 months.
Thank you for any advice you can give!
