After all the adjustments I have made, I got my hands on a DTP-94 for awhile (its not mine) and am going to re-do' my calibration as I'm now at almost 500hrs
I will post the results as soon as I can. (and my settings to give u a start)
I have only used a DTP-94 (never used any other sensor - yet)
BTW, the Dynamic CE setting in the SM only effects Dynamic & Standard modes and changes the contrast values to the highest Dynamic' setting. I have not looked at the Dynamic Dimming setting yet turning it on/off does nothing as far as I can see.
Also, I had a little scare last week as my black levels shot threw the roof. It took a good 4 days before they just settled back and now my panel looks brighter as well. This is why I decided to re-calibrate.
Now, about the Day/Night Cal modes, I cant find anything in the service menu that will allow you to turn all the enhancements off or set everything flat. I did a gamma test of both modes and found that IRE20 and IRE75 have A RED jump and you cannot compensate without having green/blue shoot up too high globally. Must be a limitation imposed by the Dynamic Contrast processing. These modes also yield a brighter picture (similar to Dynamic/standard modes)
See attached reading using custom outboard broadcast meter/monitor with a Vegas ramp.
(Default settings)
I will also calibrate the Day/Night cal mode as well and try to flatten the red.
The red spike causes a pinkish look to whites in the IRE range effected.
As for the CMS options in the SM: See arfster's post above as he explains it perfectly.
Setting the options here are very similar to colour correction in video/film post where there is a colour gamut baised on degrees reperesented in a circle. You will always need to reference a change here. Only difference is the values change degrees above 40 and your values are reperesented in HEX.
