I am building a HTPC rig, wich will also be used for gaming, I have a pretty large media library (stored on fileserver), so i think some beef will be nice. (for searching files, general snappiness and so on).
I have the following setup planned:
Case: Antec Fusion Remote Max - Not very nice looking, but large and good airflow.
PSU: Seasonic M12 550 - Old PSU i have, should do the job I think
SSD: Intel 80GB gen 2. - Silent, and with good performance.
Motherboard: Asus P755D EVO - maybe the piece I am least sure of, any know problems with this board? Coil Whine or similar?
GPU: Powercolor HD5750 SCS3 - Pretty much given, only fanless 5750 I could find in norway. Will be used to output HDMI to TV.
CPU: Intel i5-750
RAM: Kingston value 1333, 4*2 GB
Cooler: Scythe Ninja Rev 2. - My preliminary choice, based on the height clearance, the best tower coolers seem to be a bit to tall for the case(?)
(see also http://www.silentpcreview.com/forums...8d7f3eff2889ab)
Blu-ray-player: LG CH08, seens like a nice drive, is it support by programs that slow down the drive? I would rather not hear it while watching movies.
I plan to attach a 120mm-fan to the GPU, and run it very slowly, maybe around 400 rpm. The CPU-fan should run at about 600 rpm, which is a good level for low noise. The CPU is pwerfull enough with some to spare, but I am slightly concerned about cooling it. I will not be overclocking, suggestions and comments are welcome.
AtW
CPU: Intel i5-750
AtW
