AVS › AVS Forum › Video Components › Home Theater Computers › Harmony Remote not working with BluRays in TMT3
post #1 of 7
I have a Logitech Harmony Remote which is working just fine for playing DVD's from WHS via WMC7/My Movies 3. I just recently started adding Blurays, playing back via TMT3/My Movies 3, and it seems to be ignoring all of the basic commands. The keyboard hotkeys work fine. Anybody else have a similar problem?
My HTPC case is an Antec Fusion Remote Black with the Imon Software installed.
post #2 of 7
My Harmony One remote is working fine with TMT3 and Blu-ray discs with one exception: If you have just moved the mouse, you have to wait about 5 seconds with no mouse movement before it will accept MCE remote commands. Annoying, but not fatal.
post #3 of 7
Did you have to perform any additional setup in TMT3 or IMON that you remember?
post #4 of 7
No, I didn't have to do any special setup at all. My MSFT MCE receiver was plugged into a USB port when I installed the OS, and it just worked from the start.
post #5 of 7
post #6 of 7
The iMon software is your problem. If the link above doesn't help then you might need to create a profile in iMon for TMT3.
Just another reason to hate iMon/Soundgraph.
post #7 of 7
Fantastic, that's the link I needed. I also found another thread which says people are still having trouble when they use bluray folders instead of .iso's. Guess what I've been ripping to...
Off to experiment (ugh)...
