AVS › AVS Forum › Audio › Speakers › Shorter speakers than Studio 100s?
post #1 of 7
I have Paradigm Studio 100s for my fronts with a 690 center. I'm using them for 100% HT and games in a dedicated theater with an Arcam AVR600.
Now I'm starting to mold the theater room, and with the size of the inlet in the wall where the screen is, I think the 100s are too tall as they're going to be in a built in. I think they're 45 inches tall.
Does anyone have any ideas of shorter speakers that would play well with my Arcam? Also, would a new center be necessary? I do like the 690...I'm not sure I ever really take the 100s to their potential so I don't feel too bad with selling them and getting something better....just not sure about compatibility and options....
Would appreciate anyone's help! Thanks.
post #2 of 7
I'm sure you have thought of this, but why not Studio 60s??
Ron
post #3 of 7
Ron
That was actually my first thought, but they're only 4 inches shorter. I was thinking like a foot shorter...if that's even possible without sacrificing too much quality.
Thanks for replying...
post #4 of 7
OK, so I guess if you really like Paradigm (I do too !) you might start thinking about in-wall LCR's or one of their other in-walls that have virtually identical components?
I guess you could go to B&W...they have some high-quality "squat" speakers.
post #5 of 7
I know they are discontinued now, but mabye some preowned Studio 40s.
post #6 of 7
I went thru the short speaker search, mostly because I want to place my LCD TV at a reasonable height above my towers.. I plan to have 3 of the same speakers across the front.
I am half for Monitors with stands and half for towers.
I won't mention monitors because no matter what you can get a stand to fit.
BUT towers, the shortest "tower" I found was the 99dB efficient Klipsch Heresy III
PSB Imagine T are short also.. Of course I drool over the B&W 802D! I would have to budget for amps to match and right now my living room isn't ready for a "Lamborghini"
Any other sub 35" quality towers out there?
post #7 of 7
I have never had the chance to listen to a set of Heresy's, but I have read nothing but good things. They have a lot going for them.
Good sensitivity.
Large mid woofer.
Horn mid-range.
Horn tweeter.
Large source of parts if you have any problems.
  Back to Forum: Speakers
