Hello to all,
Well in a couple of weeks we will be moving to a new house which has a pretty "slim" space for the basement. Here are the dimensions.
10'8" X 21' with very low 6'7" ceilings in half of the room and 7' for the rest of the room.
Here is my equipment:
-Klipsch Corwall speakers 82 build date (love these things, but will cause so many problems in the install)
-Temp DIY center, large quality components used. Sounds very good to me. (will most likely be changed down the road)
-4 Saphire SAT1500 surround speakers (bought because product was disc, sound very good in my small condo next to my panny plasma)
-DIY huge 15" Sonotube sub
-Energy 8' sub (used in condo)
-Yamaha HTR 6160 receiver
- PS3
- SA HD cable box
-Panny PT AE4000
I don't have a screen yet because it is part of my dilemma.
My cornwalls are 25.25" wide and 36" high making almost impossible to put them beside the screen on the 10'8" wall I was planning to use.
Here are the options I am considering:
-Fake wall to put speakers behind with AT electric screen in front (Plasma mounted on wall) using 10'8" wall (120" screen)
-Same thing with fixed AT screen no plasma
- Use the 21' wall with approriate screen size for 10' viewing distance. Eliminate AT screen used regular fixed screen
- Change cornwalls to something smaller that can be placed below screen on 10'8" wall and used regular fixed screen, slightly smaller than planned 120"
- Change cornwalls and get smaller speakers placed behind 120" AT screen
The problem is my budget is moderate, after spending the cash for the projector spending another $2000 on the seymore screen is killing me... (although decent rpice).
I would'nt mind changing the speakers, but I don't to sacrifice any sound quality by buying less than stellar speakers.
I attached the pictures of the basement to give you an idea.
So after all this, I guess I am looking for a little advice on what to do with my slim room and equipment.
Thanks for any input
- PS3
- SA HD cable box
-Panny PT AE4000
