AVS › AVS Forum › Home Entertainment & Theater Builder › General Home Theater & Media/Game Rooms › New build--- theater/bar/kitchen
New build--- theater/bar/kitchen - Page 3
post #61 of 69
Originally Posted by mekkerl View Post
Did you use any kind of vapor barrier behind the walls? Or, just paint the cinder blocks and put up your framing with r-13 faced insulation?
3 coats of drylok, then a 6mil vapor barrier--- also pressure treated 2x4s for the sill plates.
post #62 of 69
Update pics!
Still have trim work, staining, painting, and to pick up the apartment fridge, but I'm getting close. Ignore the mess on the back bar!
I tried to take the pictures to show the perspective from the bar area.
post #63 of 69
Looks great. I love the idea of using the drip tray as an accent peice for the bar. I have not seen that before.
This bar is definitely one of my favorites, Great job!
post #64 of 69
Beautiful - and not one, but TWO tappers
Awesome!
post #65 of 69
Thanks! I figured they would be functional as much as they would give it some 'real bar' detail.
Awesome!
Yes! Ordered the kegs for tomorrow! I was planning to put Newcastle on tap, but at $170 for 50 liters, I think it would go flat before we'd drink it all. So, we got the crowd favorites Coors light and Yuengling.
post #66 of 69
I know this is an old thread, but do by chance have the dimensions of your bar? Im looking to build one similar, thanks!
post #67 of 69
Would anyone know where to find the Rock that was used in this bar? I checked home depot and lowes and cannot find anything that looks like it..
post #68 of 69
Wow its fun seeing this old post resurrected! The stone is Owens corning pro-fit ledge stone. Its a cultured stone veneer. If you happen to be near Pittsburgh I still have 2 boxes left over. You should be able to order it from most building supply companies. I got it from a local place. Price is pretty standard everywhere I called. Hope this helps.
post #69 of 69
Great! Ill get to googling smile.gif .. I was presently surprised to get a response. Good looking bar btw .
