Hello all,
I wish to convert from RGB tv video (with one, separate sync) to VGA or anything "contemporay and off-the-shelf".
I appreciate your time and assistance. I fear I cannot offer enough detail, but I figured I would take a chance and seek out sharper minds. I apologize upfront for my ignorance.
I support a chip placement machine that utilizes a 14" tv monitor (which is now obsolete). This monitor accepts R, G, B and S inputs from a proprietary video card. The vendor (based out of Eindhoven, Holland) no longer supports this model and cannot offer any technical help. Out of 6 tv monitors, 5 are no longer working. The vendor's solution is to purchase a JVS monitor for $1500. I hope I can discover a cheaper solution!
ORIGINAL TV MONITOR SETUP:
Output (from machine video card): Discrete R, G, B, S with SMB connectors
Input (to obsolete tv monitor): 9-pin D-shell
VENDOR RECOMMENDATION TO REPLACE OBSOLETE TV MONITOR: utilize JVC 15" color, model TM-H150CG
Output (from machine video card): SMB connector on G output only
Input (to JVC tv monitor): SMB to BNC adapter to "Video Line A IN".
The replacement monitor is a JVC 15" color monitor, model TM-H150CG.
I did buy one, and it does work. However, I need to replace 4 monitors immediately and stock one spare for storage. Hopefully, one may be able to recommend conversion hardware or a different, less expensive tv monitor.
I hope I can find a solution better than a $1500, 15" tv!
Again, thanks for your help!!!
