AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › New Casio projectors: LED/Laser, 720p, compact
New Casio projectors: LED/Laser, 720p, compact - Page 12
post #331 of 875
Originally Posted by 3ukman View Post
will XJ-240 Wireless be ok to use as a monitor replacement - i.e for browsing web-sites and Ms Word. in Eco 2 - lowest noise level...
From some XJ-A135 reviews posted previously:
Originally Posted by ZDNet View Post
Casio's Wireless Connection software allows up to four computers to broadcast information to the XJ-A135 simultaneously, with the projector splitting the screen in half or into quarters accordingly. The Wireless Connection software must be installed and running on each computer, but other than the initial setup time it's relatively easy to use. The software is included on a CD with the projector, although there's currently no Mac version.
Link
Originally Posted by Expert Reviews View Post
There's no need for a VGA or HDMI cable as the XJ-A135 has built-in WiFi. Once you've installed the software from the CD, a small taskbar appears on your desktop and automatically attempts to connect to the projector. It asks for a login code, which is displayed by the projector for a couple of minutes after you switch it on. This also shows the projector's SSID and IP address in case you need it.
Once connected, your desktop is automatically mirrored and displayed by the projector. The only flaw is that it you have to manually change your screen resolution to 1,024x768 for the best quality; non-native resolutions make text look distinctly fuzzy. Bear in mind, too, that you'll forgo wireless internet access while your laptop is connected to the projector, so it isn't much good if you need to show your audience live websites.
The utility - oddly named Wireless Connection 3 - provides two options: high speed or high resolution. The latter is the best choice for PowerPoint presentations or any other demonstration where you want the best quality. High speed is designed for videos, although we never saw smooth playback even with very low-resolution clips. We'd estimate it managed around 15-20fps, but it wasn't simply jerky motion that made the videos unwatchable, it was the horizontal tearing that meant there were split seconds where half of the previous frame and half of the current frame were visible.
Link
Originally Posted by jang790 View Post
awesome pics !! could you post some pictures through hdmi (hd) source
I think he was using an HD source in that picture. It's tough to get good pictures of video on projectors so just keep that in mind.
post #332 of 875
Lol yes i always use hd source (but compressed), my camera is a little old, not precise as reality.
You can see my A/V receiver is not precise on the pic, so you can think the picture in the screen will not be sharp ^^ (but it is in fact).
Another cool pic:
And congratulations for USA soccer team, the match was very good against UK
post #333 of 875
cool pics !! keep em comin by the way how big (inches ) are you projecting
post #334 of 875
118 inches (i love big screens ).
i took this pic with the cam behind my sofa:
post #335 of 875
nice pics cfcmoon. what do you think about black levels of the projector
post #336 of 875
Good, black is black. The difference between levels of black are more difficult to have, but it's not a high end projector, it's normal i think.
I saw germany vs australia (it was fantastic), and i found my best settings i think: theatre mode with red -10 green 0 blue +7.
I have 428 hours, using time.
post #337 of 875
cfcmoon, if I only use for watching dvd, a-130 is good enough to project 100 -150' screen?
post #338 of 875
80-100 inches but no more, if you want more you need the 240.
The xj-a130 have 2000 lumens (theorical) max in fact less. In eco2 it will be between 600 and 700 lumens (real) i think.
The 240 have 2500 lumens (theorical) max and in eco 2, 800 lumens (real).
But if you can tolerate more sound in eco1 (eco 1 sound is strong but 35 db it is possible with a strong home cinema movies sound behind lol), you will can increase screen size. Full mode is ... Impossible to tolerate lol (or in a street perhaps ^^).
post #339 of 875
Hi
New pictures from Casio XJ-240 on Eco 2
with my Casio Exilim. 120 inches projection
[IMG]http://i48.tinypic.com/35ipyfr.jpg[/IMG]
post #340 of 875
More pictures from Casio XJ-240 on Eco 2
post #341 of 875
post #342 of 875
post #343 of 875
post #344 of 875
post #345 of 875
post #346 of 875
post #347 of 875
post #348 of 875
post #349 of 875
post #350 of 875
Great pics. Have you done any adjustments? Picture looks a little soft and maybe brightness could be turned down a little?
post #351 of 875
I'm sorry my poor english, but I will try to explain
No, I have not done any adjustments.
The photos are a little saturated and brilliant, maybe 15 to 20 %, because the digital camera does it automatically, but the appearance of the photos is very similar to the projection.
I have taken the photos with a digital camera Casio exilim, to 50 ISO and disconnected the automatic light.
The focus it changes from scene to scene, depends much on the quality of the projected movie
post #352 of 875
can you ceiling mount the XJ-A240
post #353 of 875
Hola Orlando, te consulto, recomendarias este proyector para ver pelis, el contraste y los negros que tal son ? GRACIAS
post #354 of 875
Yo recommando ese proyector para pelis sin problema, pero es importante de ajustar bien todo (colores/luz/contraste).
Cuando lo utilizas por la primera vez puedes ver que todo es mal arreglado, ademas hay que esperar 300 horas para tener las verdaderas colores (el laser azul necesita tiempo etc).
Los negros son bien negros, estan bien, talvez es dificil de tener todos los niveles de negros, pero el negro es bueno.
Mis ultimas imegenes fueron borradas grrr, no suerte.
Se ve en las fotos de orlando1946 que no es arreglado como las mias.
post #355 of 875
Es el primer proyector que tengo y no tengo experiencia en la calibración y en la parte tecnica, pero me parece un buen proyector para HDTV, peliculas, presentaciones. Lo recomiendo.
post #356 of 875
post #357 of 875
post #358 of 875
post #359 of 875
post #360 of 875
