Ok, I've been searching for awhile now for a replacement for my Sony KDL-26M4000.
I would like to stay w/ a 26" set since that is the largest size that will fit where I'm going to put a TV.
I've narrowed it down to the Sony KDL-26L5000 and Samsung LN26B360. Which has the better panel? Sony's site says the 26L5000 has an 8-bit panel, but Samsung's site shows that the LN26B360 has a higher contrast ratio than the Sony. Also, Sony shows that the viewing angles are 176/176, but Samsung doesn't show that either.
Which set is better?
I'm also looking at three Panasonic Viera sets that have the IPS Alpha panels (better viewing angles).
They're all 32" and will be used mostly with HD QAM channels and SD channels. I will also connect it to my PC and watch online HD content.
I will be sitting anywhere from 4 to 10 ft. away from it. Also, I know everyone says that manufacturer contrast ratio measurements don't mean much, but what if all the TVs being compared are from the same manufacturer? Their contrast ratio measurement does mean something then, right?
The choices are:
Panasonic TC-L32G1 - 120Hz, 720P, 20000:1
$529.95
http://www2.panasonic.com/consumer-e...model.TC-L32G1
Panasonic TC-L32S1 - 60Hz, 1080P, 15000:1
$456.39
http://www2.panasonic.com/consumer-e...model.TC-L32S1
Panasonic TC-L32X1 - 60Hz, 720P, 12000:1, iPod dock for viewing / listening to content on an iPod
$434
http://www2.panasonic.com/consumer-e...model.TC-L32X1
Which one should I get?
The choices are:
$529.95
$456.39
$434
