OK, I'm no noobie; in my time I've streamed my own video files to a Mediagate MG-35, XBMC on XBox, PS3, PCH A-110 and C-200 (different solution for audio). They all served their time and purpose, and the XBMC, PS3, and A-110 still remain (the MG-35 was my first box, and was replaced by the XBMC...and the C-200 was ahead of its time, and not really suited for me).
However, I'd like to take the next step...which for me means both online content, and also trying to focus on one solution around the house. After I tried and dumped the C-200, I decided to try my first hand at HTPC with the Dell Zino HD. I don't have the time to fiddle with the set-up that HTPCs seem to require, so that solution isn't going to work for me either.
So...that leaves me looking to what's next. The XBMC is comfortably in my Bedroom system for now, and the A-110 rests happily in the HT. So that leaves the Family Room. Believe it or not, this is where I have the most trouble, because the Bedroom just needs to play my own SD files...so XBMC works like a charm...and the HT just needs to play my own HD files, so the A-110 kicks that out. It's in the Family Room that I'd like to do it all; SD, HD, online, etc.
I don't really know what's out there, online-wise, but I suspect my focus will initially be Hulu, Netflix, Fancast, etc. The PS3 is already in the Family Room, and does too many other things to make itself obsolete...so in the interim I'm trying to bend it to serve that room. PlayOn has proved to work OK with Hulu...so far as I can tell in my limited experience...but I'm not sure which other sites it works well with, how well it does HD, and I know the My Media is a bust for me; so is it worth $40 just for Hulu? I suppose I could try some other media servers, like ps3mediaserver, but I'm not interested in changing my ripping process, and stripping down my files...and I don't have a scream-machine of a PC that I'd want to do on-the-fly transcoding from, so I don't know that the PS3 will really fill all my needs (realizing, early on, what the PS3 could and could-not do well is what drove me to a PCH A-110 in the first place).
So just as I was searching for the next thing, along comes the announcement for the PopBox. I love the A-110, and even though the C-200 didn't work out for me, I'm happy to back Syabas as my one solution around the house.
Of course, as I'm looking around, I decide to see what the XBMC on Acer Revo is all about. Hmm...I love the little form-factor of the Revo; and I have to admit, XBMC is obviously an awesome media server, and has never been anything but simple, simple, simple to use...albeit for the limited functionality of streaming my SD files to the Bedroom system.
So I'm torn, and looking for a little feedback. I know everyone has their favorite, but...can I do anything with the PS3 without bending my files too much? Is the Acer Revo going to be, basically, like my experience with the Dell Zino HD; it's a PC and HTPCs require a lot of tweaking? Or does just sticking an XBMC build on it eliminate some of that hassle with drivers, set-up, and tweaking? The PopBox looks very promising; should I just hang in there until March and give that a try?
Thoughts?
CD
Thoughts?
CD
And tv series on Blu-Ray are the worst, because without that menu, you're going to have a hard time navigating.
