AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Official Rythmik Audio Subwoofer thread
Official Rythmik Audio Subwoofer thread - Page 397
post #11881 of 15114
That is correct. Music sounds great with damping set to high with bass coming through as clean and articulate. Movies have more impact when set to low. I listen to both equally (50/50).
post #11882 of 15114
I have my two F12SEs set to High, even for Movies. In Low I get complaints from neighbors upstairs. mad.gif
post #11883 of 15114
These are choices between max output capacity (2 ports, low dampening, high frequency) and max low frequency extension (1 port, high dampening, low frequency). They all do it in different ways, so any combination could be your favorite. It's a lot of options to understand, but that's better than having to buy a new sub if you decide you want something different.
Details:
http://www.rythmikaudio.com/eq.html
post #11884 of 15114
A bus and a small child for reference. Looks like shipping hurt the outside of the boxes' feelings a little bit but I'm sure all is well inside. Can't wait to set them up in a month. Happy Thanksgiving.
post #11885 of 15114
Details:
Yes it really is a lot to understand esspecially with the 1-2 port option.
So far I enjoy the 14hz , hi, 1port and I also really enjoy 14hz 2port med damp. Should give me flat to about 18hz.
I might have a bit of a low frequency null becuase I cant hear\feel much of a diffrence in the 12vs 18 hz extension. Only very slightly can i FEEL the diffrence in the 12hz ex mode.
Anyone else use 2 port mode?
As I said before I have plenty of output in 1 port mode but I seem to enjoy the 2 port mode listed above...
Edited by newc33 - 11/28/13 at 5:01pm
post #11886 of 15114
Please give feedback on impressions and settings!!
post #11887 of 15114
What movie or material were you watching or listening? If the content does not have down low frequency, you won't feel the sound with 1 port mode.
post #11888 of 15114
Grenade scene wwz
What settings do u like for movies?
post #11889 of 15114
In do like the 1 port 14hz hi/med the best so far. Just saying I do enjoy the 2 port 14hz hi/med as well
post #11890 of 15114
So everyone wanted a more in-depth review of my up and running dual F25 setup. New update time after a couple more movies:
EVEN MORE AWESOME THAN PREVIOUSLY REPORTED.
How's that?
post #11891 of 15114
Grenade scene wwz
Honestly, I haven't really play with those settings much but stick with what Brian's recommendation for movie (14/low). When I have time, I will play with these settings.
Are you running your dual fv15hps with your lv12r?
Edited by Cowboys - 11/28/13 at 6:17pm
post #11892 of 15114
I have to fv15hp and run both ports open due the large space (roughly 6000 cubic feet when taking into account all open adjacent spaces). I have settled on med for both movies and music. I am so used to med that I can hear what I am missing with low. I have a harder time hearing the difference between med and high. I can hear it but only when critically listening so I have settled on med. If I ever bought a second sub I would probably still run both subs with both ports open due to large space I have to pressurize. If I move homes and can have a dedicated space then I would definitely switch to one port.
post #11893 of 15114
^^ can you explain what's missing switching to low from med? Thanks.
post #11894 of 15114
When you switch from hi->med->low, you get a steeper filter slope. This does a few things:
1) It reduces output in the lowest frequencies.
2) Reducing low frequency output saves amp and driver extension headroom, so you get more power higher up.
3) The steeper slope can cause ringing (smearing of detail) in the lowest octave.
4) The steeper slope can affect phase more, although Audyssey (especially XT & XT32) supposedly corrects for this.
You ability to hear the difference depends on content and the room. I couldn't hear the difference in my room until I had multiple subs split across the front and back of the room, since I was sitting in a null. If you can't hear the difference, you sacrifice nothing for more power.
Some rooms need the extra power.
Taste is also a factor.
While it's helpful to hear about other people's experiences, it won't necessarily apply to you.
It's also helpful to experiment with the frequency and port options.
post #11895 of 15114
^^Thanks for a detail explanation.
post #11896 of 15114
Was wondering if I should put my LV12R on an isolation pad being that I have hardwood floors?
Auralex SubDude HT for $70 shipped
post #11897 of 15114
Protecting one's hardwood floors, high WAF.
post #11898 of 15114
No wife....lol
I actually have tiny furniture sliders under each leg, just in case I need to move it around.
Is it worth the $70 for decoupling? Thanks Beee Man
post #11899 of 15114
The smearing of detail in lower octaves is my experience. The sound is still way more detailed than any sub I have owned before even in low. But now that I have experienced and adjusted to cleaner bass I can hear the difference. I have a hard time listening to music in the car now... need some rhythmic car audio solutions :-)
post #11900 of 15114
post #11901 of 15114
post #11902 of 15114
post #11903 of 15114
Speaker stands are temporary lol
post #11904 of 15114
Do you have a wood subfloor or concrete? If you have a wood subfloor, try a stomp test on the floor and see how sturdy the sub-floor is. Normally, you want to place the sub on a location with strong foundation to minimize vibration. Stomp test can help you locate that. The decoupler is most effect when the sub-floor is less than ideal. If you already have concrete subfloor, all subdue does is raise the height of the subwoofer.
post #11905 of 15114
Yup tvs next. I almost bought one this black friday but I have spent quiet a bit of money in the last couple weeks (fv15hp, christmas shopoing, new dslr camera for wife etc..) plus I'm going to be working away from home for almost 6 months so I wouldn't even be able to use it.
I would also like a new reciver. Somethiing that will eq my subs. That way I can hook up this reciver downstairs to my pro cinema 600 setup
post #11906 of 15114
The floor (2nd floor) that the sub is on is just hardwood (bamboo), no concrete. My 1st floor is concrete, but no subs there.
post #11907 of 15114
post #11908 of 15114
Then stomp test is good. A good subwoofer placement should also take structural rigidity into consideration. Along the wall that you can place subwoofer, maybe there is one or two locations that you have supporting walls. Stomp test can tell the difference.
BTW, the sub does come with rubber feet (ideal for hard surface floor) and I assume you are using those.
post #11909 of 15114
Out of curiosity, how available are the FV15HPs?
post #11910 of 15114
Then Denon X4000 or Marantz SR7008 are you best choices. I have a Marantz SR7008 and XT32 with SubEQ HT did an amazing job with my two F12SEs.
