Originally Posted by DonH50
In response to your first answer last (follow that? not sure I did...) my mains are planar bipolars -- Magnepan MG-IIIa's -- so phasing gets a little complicated. The good news is that they are very linear speakers (good impulse response); the bad news is that the room's influence is huge on the wavefront at the listening position due to the reflected waves. To further complicate things, there's an inversion (180 deg shift) in the system to the mains (not sure where it's at, just that the AVR's cal routine caught it).
In the ideal case, the dipole has an additional 6db/oct roll-off with corner frequency determined by the baffle width. Other than that, it is same 2nd order roll-off as the sealed speakers. So it is 3rd order, between 2nd order sealed woofer and 4th order vented woofer. In your case, the corner frequency (where it has additional 45 degrees shift) should be above 200hz. So when it goes down to 80hz, we should have close to 90 degrees phase shift. I would treat it as vented. There is a difference between 180 deg shift and inversion. The 180 deg shift can be from a high pass filter just like a vented subwoofer at the corner frequency of roll-off. But if we conclude the signal has been inverted, that would be incorrect. I normally look at the phase plot as a whole to conclude if the signal has been inverted.
One final question/comment for you or whomever: Do you suggest spikes under the subs? My media room is in the basement so has concrete under the carpet, but there's a fairly new (thick) carpet and pad on top. I realize the weight of the sub will flatten it down, just curious. I never would have believe Doppler effects matter for audio speakers, but some listening and measurements convinced me otherwise many years ago.
You can use spikes over carpet. I don't recommend spikes over hard floors. The improvement from spike is very subtle with our subwoofers.
» Get the latest news and updates at the Rythmik sponsor page.
Quick iPhone picture...
