Is anyone using multiple subs that they've connected using the balanced XLR inputs/outputs via the "Source In" and "Slave In" plate amp connections?
After reading Dr Floyd Toole's latest book I'm sold on the idea that 4 subs is the way to go for best small room bass. Given the length of cable runs it's likely XLR would be better than RCA and I'm planning on putting a professional studio analogue Parametric EQ upstream of the 4 subs to attenuate bass mode peaks with 5 seperate EQ's per channel.
My understanding is that in using the Source In/Slave In that the source's sub volume control also controls the slave's volume, which may not be a good idea if the two rear subs are closer to the listening position than the front 2 subs. . .
Finally, how does one set up 4 subs -> do you set up all 4 at the same volume relative to the listening chair and then match the main's volume dB to the sub's volume dB?
