AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Official Rythmik Audio Subwoofer thread
Official Rythmik Audio Subwoofer thread - Page 154
post #4591 of 9667
Originally Posted by Rythmik View Post
As I am offering these advices, one can see that these are compromise between various aspects of perceived sound which deviates from my preference of having a neutral and transparent sound. While Nith has mentioned the chest ponding feeling, how are the other aspects of bass in the show room? was the dialogue still clear? or they all appeared to have thick voices or muffled? In the special effect to building tumbling, do you hear the shock rippling effect, or just one single boom. These are all different aspects of bass reproduction and they are often not completely orthogonal (or independent). It is almost like an illusionist directing our attention to a particular area only and away from all others (instead of the visual effects, the illusion here is the audio effects). That is fine. But in the end we need to know what aspect is most important to you.
There is virtue to Brian's approach. It took me a bit to adapt to the articulate and transparent sound that was new to me. It felt like the bass was lacking, but it was only the boominess that was lacking. I've been used to that common boominess for 50 years of listening and associated that with bass is. Once I let go of that notion, I started hearing the bass instruments. Instead of the bass instruments just contributing to that solid bottom feel, they became instruments of their own contributing to the intricate fabric of the music.
I've always appreciated Phil Lesh's bass in the Dead's music and Cream's live crossroads has been one of my early favorites. I now realize this was partially due to the articulate nature of Lesh's and Bruce's bass playing. I now have that quality in all music. And when it goes low - I mean really low - it floors me (pun intended ). I get that extremely deep wow bass only when intended from the source. I don't try to get wow bass with everything all the time, it's not meant to be there all the time.
Running two F12 with AVR mode - 14Hz - mid damping - rumble off - PEQ off. The Audessey XT32 in my Onkyo 5508 helps alot no doubt.
/soapbox off
post #4592 of 9667
Or move the frequency to 80hz and boost that band. A lot of these can be done with AVR fixed band EQ setting. Boosting midbass band can give you higher midbass slam. Set the damping to low and move the extension filter to 28hz will fiter out reverberation and let us hear and also the sub conserve more power on the initial attack.
Doing so would get me nothing below 28Hz. Compromise...compromise. It would be perfect if the Extension Filter (High Pass) has 50Hz option. Then I could configure the other sub to 50Hz/24 (Low Pass). I'll give a shot at 80Hz, though.
The showroom was not treated. The sub was placed midway in the room along one of the wall. The demo material was not a movie per se; it was a documentary material with male voice narration and instrumental music in the background. The music was mostly kick drum with occasionally 'heart beat' sound. I believe these sounds were mostly in the 60-80Hz frequency range. The narrative was clear. I believe the crossover was set to 80Hz. The AVR was a Pioneer Elite.
I want it all. Seriously, I do. Since I wanted both the accuracy...transparent and the midbass 'slam', I needed a system that could evolve over time. With this in mind, I needed to start with a sub system that could produce transparency and accurate bass because I knew that I could not make a bad sounding sub to produce accurate sound...but I knew I could make the sub that could produce transparent and accurate bass louder. Rythmik met the criteria and budget.
Lastly, changing to vented box will need 8-10 cu ft boxes (twice the enclosure size of single driver). I would recommend to go with DS1510 driver, instead of building that huge 8 cu ft box.
I like the idea to go with the DS1510, but that means my 4 DS1500s will be on the shelve. The vented box is just going to be a prototype. If I like the sound, I may opt for the DS1510. But I know I will not get the 'kick in the chest' with the ported configuration since 40Hz and over the sealed vs ported is nil.
post #4593 of 9667
50hz highpass? Not a problem. Our preamp board is very easy to fiddle with. We can discuss that off-line aboutwhere to solder what to get that. This is strictly for experimenting purpose. In production, I don't want to have 10 different configurations. That will wear me out
We can help you out to trade them in for D1510 in the end. We are flexible.
post #4594 of 9667
It's great to know you go this length to customize the amp to make a customer happy. Thanks! After I got the PEG working, I don't think I need the 50Hz High Pass anymore. If I do need in the future, I'll just use a DCX2496 to handle it. About the DS1510, I'll take you up on that. Seriously, though, I would pay for them...I don't want you to absorb the loss like that.
The PEG setting does WORK this time!!!! My grin is wide from ear to ear . The last time I tried was GAIN=+3dB, BANDWIDTH=MAX, FREQ= 12 O'clock. The FREQ @ 12 O'clock is 40Hz; no wonder I didn't notice anything. I didn't realize that each dot represented 10Hz. The FREQ is now positioning @ 60Hz; will try 70Hz, 80Hz another time. I like it!
post #4595 of 9667
Originally Posted by mjodotcom View Post
I think I misspoke a bit. The bass isn't really "boomy", I would say more "muddy" or "sloppy" are better descriptions of what I am observing at the new spot vs the old - also a bit louder. Seems like going to the higher damping helps. Anyone have any other ideas?
Still looking for some direction here on why a flat FR can yield undesirable SQ and some techniques to try to fix it Thanks all!
post #4596 of 9667
MJO.com,
Have you heard a flat frequency response in the bass region? To my ears (your's may differ) it sounds anemic. That is likely due to the ear's reduced sensitivity to lower frequencies as seen in Equal Loudness Curves research. Flat frequency response in the mid to upper frequencies is usually a noble goal.
When I bought two Rythmik F15 subs I knew I was in for many long nights of sub placement trial and error - one sub is hard enough, so two must be more difficult I thought. What helped me was to use painter's tape and mark off all possible sub locations on the left and right sides of the room and also the front and back walls. Then I enlisted the help of the Dayton Audio OmniMic to take Frequency Response VS SPL measurements for every combination of possible sub locations - 99 in total!! Took me two hours of luging subs around and saving each measurement before going back and looking at them all for something that looked more akin to the equal loudness curves. Then fiddle with the phase, volume and cross-over frequency of one sub and then do the next so that the overall system response is to your liking. If you can get a gently rising bass SPL as freq falls without peaks then your bass reverb time should benefit.
How many subs are you using and do you have a measurement tool?
post #4597 of 9667
Originally Posted by kevinzoe View Post
MJO.com,
I am using one sub and tried out about 10 different spots in the room, measuring the recorded value from my SPL meter when playing test tones and pikes the spot that both has the flattest starting FR to eq from and the most even FR across my couch. After room correction (XT32), my selected spot is flat to +- 3db minus a slight null at 23hz via this method. The test tones CD plays in 1hz increments from 20-80hz, 10 sec on each tone. I did calibrate out my sound meter using values found on this form. Feels like I am doing everything right?
post #4598 of 9667
In the real world, the flat frequency response may not yield the best sound, in particular for front speakers. If a flat FR is all we need, the speaker designers will be replaced by computer software. A lot of times, the flat FR is the first shot solution (or so-called initial solution), and then the designer comes to fine-tune it using his ears (a process called iterative improving). Maybe the tweeter is too bright, so we can attenuated more on tweeter. Or the midrange is too forward or too layback,... This is just one aspect. Eventually he may find the Q value (or impulse response), phase response, voice coil weight, rubber surround material (creep effect), cone material, and other factors not listed here all affect sound. This is just the complexity of the problem. Then the components in crossover design. Some components sound brighter than others.. That is the second layer of fine tuning. If one has unlimited budget, component cost is not a problem. However, on commercial speakers, finding good sounding components with reasonable cost is trickier.
If you think about it, this industry is a bit disconnect from various related fields. The transducer designers do not understand how electrical circuits and components affect sound and think transducers are the only one matters. The electrical engineers think flat frequency response is the only one matters. Not too mention we have software guys have their opinion.
Even for transducer designers, we have one with Ph.D background (you know who) think his waveguide design is best and for bass, all you have to do is add a bunch of subs and mix them. Sure, subwoofers are just commodity. Why doesn't this "many subs and commodity idea" apply to his waveguide speakers? All engineers look for unified theories so that they can apply the idea to a wider scope. If I believe servo subs sound better, I will naturally think servo midrange drivers should also sound better. Bass is just other frequency band: common sense applies.
In short, to answer why flat F/R bass may not be the best? I don't think we fully understand how we perceive sound quality. Just like someone has an illness with many different symptoms, including headache. If the doctor cannot find the root cause or the relation between various symptoms, all he can do is prescribe pain reliever and treat the most obvious. Well flat FR is our easy target here. So if flat FR gives us good sound, that is great. But if it doesn't, I won't be surprised such cases do exist. But that is not to say having flat FR has no value. It is a good initial solution. A tweek here and there maybe needed.
post #4599 of 9667
Thanks a lot for chiming in Brian, glad to see I'm not crazy :P. So in your opinion what things should I try to "tweak" given the characteristics I am observing (somewhat boomy, muddy sounding bass)?
post #4600 of 9667
For boominess, it can be the echo time and Q value of the extension. I would calibrate XT32 with 14hz low damping and afterwards, change the extension filter setting to high damping 14hz or 20hz. If you'd like the sound to "firm up", you can also play with the PEQ setting on our plate amp. Setting it to +3db at 80hz with mid to max bandwidth to bring to midbass forward to you. That can change the perception of muddy sound. Have you tried set your front speakers to large and play in the same room? It will give you the idea of the bass tone quality from the front speakers.
[EDIT] BTW, what does XT32 say the distance of the subwoofer is? That information is important. If the distance information is wrong, then you need to change the crossover to another frequency that XT32 is correct on subwoofer distance.
post #4601 of 9667
If I'm not mistaken, sometime ago I read here that rythmik subwoofers with class d could be released. Any news on this?
post #4602 of 9667
Anybody ever think about building an F25 CI with vented enclosure?
post #4603 of 9667
This is all great stuff. I will try doing a re-cal per your suggestion and see how things go (does XT32 not correct for echo time and Q?).
Currently I am using PEQ set to +3 min bandwidth to bring up a room null at 44hz, so if I do what you suggest I would be sacrificing the FR a bit more - thoughts?
With the front speakers, are you suggesting that I set them to large and turn the sub off to see what it sounds like? Haven't done that yet. I did set the fronts crossover to 60hz instead of 80 before and was very underwhelmed with the results (sounded much less full)
I will have to verify the sub distance, but from memory I think it's off by about a foot. I thought the whole point of the XT32 distance setting vs actual was to account for the phase different at the crossover and the numbers not matching up was normal?
Thanks a lot for your help this far - feels like I am finally getting some direction
post #4604 of 9667
Oh yeah...I'm thinking about it just for fun. 20Wx46Hx26D isn't that big . I've been reading about port resonance frequency, it gives me the headache. Or go with PR, but then again 4 18" PRs cost about $1200...might as well buy two more F25 CI
post #4605 of 9667
mjodotcom, retry auto calibration with fewer positions like 6 instead of 8. Too many positions can sometimes make the sound sounds so weird in certain room.
post #4606 of 9667
From what I have read on the Audyssey forum I thought you should ALWAYS use all the positions you can?
post #4607 of 9667
I suspect you've heard this before but the Audyssey target curves are all flat below ~ 2k. The Audyssey answer to LF psychoacoustics is DEQ. They also give you trims and a bass control.
It's quite likely that none of those are related to your issue and you actually have a meta-probem. The most common of those is that you prefer a defect or you simply don't like the Audyssey sound.
If you take in in depth look at room response and you're seeing real problems you probably need to look into room treatments.
post #4608 of 9667
I wouldn't put it 'ALWAYS'. Audyssey recommended 6-8 positions. My sub-eq (similar to XT32 built-in) can calibrate up to 32 positions, but I used only 6 positions. Extra position(s) can cause MultEQ to make unnecessary adjustments. Denon says 6 positions is best for most rooms. Ultimately, your ears are the final judgment...you may like it with fewer position(s). There is nothing to lose.
post #4609 of 9667
True - nothing to loose. So what about my earlier question related to audyssey correcting for echo time and Q factor? Also seems like most people in the audyssey thread suggest not messing with sub parameters after cal but Brian suggested doing just that?
post #4610 of 9667
The idea behind what Brian said is that Audyssey will set everything flat so you want to put the sub in its max extension mode but also have good output while running setup. Then you can alter the sound to your liking by changing the settings on the sub.
Putting the sub in 14hz/low damping will set it to its best output it can do at its lowest frequency.
The. After setup you can change the damping to Lessing ringing, or change frequency to get more output etc.
post #4611 of 9667
To add, before I ran setup Brian had me plug one port on my FV15HP and set it to 14hz/low damping.
I then unplugged the port and set the damping to high to get the sound and output I want although at the expense of some extension.
post #4612 of 9667
Thanks for the clarification - but wouldn't changing the extension/ringing change your SQ because you are changing the input parameters that Audyssey used when finding the necessary corrections? Seems to me that modifying your extension would change your output (and therefore effect your FR curve) and changing your damping would make delays, etc different than what Audyssey was expecting?
post #4613 of 9667
This is why it can help by retrying auto calibration multiple times. After all, Audyssey is a software alogorithms, just a slight different of the mic placement, it can change how the overall sound can be heard. The 14/20 Hz, it wouldn't do detrimental to the Audyssey. It's just a cut-off frequency. I can't speak for Brian, but doing the 'low' damping while auto calibrating allows you to change to higher damping afterwards. If you did the 'high', you then cannot change to med/low afterwards -- it wouldn't make a difference.
post #4614 of 9667
Making the changes will change the sound but it will not effect delays or distance etc.
post #4615 of 9667
Originally Posted by bodosom View Post
...It's quite likely that none of those are related to your issue and you actually have a meta-probem. The most common of those is that you prefer a defect or you simply don't like the Audyssey sound....
This was the very thought that crossed my mind as I read through his postings. Nothing says one has to "like" a flat FR... by all means, "season to taste" and enjoy.
...If you take in in depth look at room response and you're seeing real problems you probably need to look into room treatments.
This also is a good suggestion except that it does have its limitations when applied to low frequency.
post #4616 of 9667
Guys,
Can someone explain to me what the Bass Extension Damping of Low, Hi, Mid means as I thought the best setting for music was 14hz/Hi but it sounds like people are suggesting 14/Low . . .?
post #4617 of 9667
Guys,
The best sound for music is 14hz/hi damping. High damping has less ringing and it has a much more gradual roll-off.
The setting for auto calibration is just temporary. Let us assume the software is capable of achieving same consistent calibrated response if the pre-calibration curves are well behaved. BTW, switch damping control does not introduce new peak or null, so it is reasonable to assume Audyssey will come back with very similar calibrated curves. If one set the extension to 28hz, the software may even boost the band between 20hz and 30hz. So the idea to present the low damping curve to calibration program. And then check the sound. If you think it is too boomy, then you can switch the damping back to high. If one had used high damping for calibration, then there is no "ultra" high damping setting to fall back to. If the sound is good, there is no need to make further damping adjustment.
I encourage everyone to adapt the idea. Alternatively, one can also use 14hz/med damping for sealed subs and afterwards, one can use low damping to make the bass even more "full body" (or boomy)by switching back low damping, or more articulate by switching back to high damping. Of course, there is nothing wrong using 14hz/high damping for calibration if the result is right on what you expect. My rationale here is the software should also give you very similar calibrated curve if the damping were set to med damping or low damping. For vented subs, my recommendation is to use 14hz/low damping as the vented subs already sound more full body than sealed subs.
MJ.com,
When I say fine tuning, it is not meant to do huge adjustment. You may do a +/-3db to adjust because bass is less sensitive. In the example case I mentioned for front speaker design, a +/-1db adjustment already sufficient to make audible difference.
The reason I mentioned distance is important is one can use a common sense of physical distance plus and minus 1/2 wavelength as a sanity check window. If the software comes back with difference distance, it means the software was not able to calculate the distance correctly because the input data have huge anomalies that is either from strong reflection or other source. That is the first indication there is some trouble in the setup. We should do something to "help" the software. One thing we should know is sound travel faster then air. If one place the mic too close to the wall, hypothetically it can cause problem. Note that 1/2 wavelength means 180 degrees in phase difference. It already has sufficient margin to account for all errors. In reality, the actual value should be well within that range. For instance, wavelength of 80hz (the crossover point) is 12ft. Half wavelength is 6ft. So your sub distance should be within physical distance +/- 6ft. When something like this happen, try a different set of inputs and placement. If you got to have that placement location, you may need to do manual calibration instead.
post #4618 of 9667
nith,
You were right. I did last night Audyssey again but just with 6 points (instead of 8) and the sound is much better by far. BTW, my AVR is an Onkyo TX-NR809.
Also I sold my Velodyne SMS-1 because I'm not getting any additional advantage in SQ over Audyssey MultiEQ XT. BTW, Audyssey says my F12 is 5.5 ft from my seating position, but it's just 4 ft. I changed it manually to 4 ft and it's working right on phase
Thank you so much!!!
post #4619 of 9667
I'm saving for an F25 CI or my F15HP CI at this time, otherwise I would build it myself and try it. If you do, I'm interested to hear your impressions.
post #4620 of 9667
Rythmik wrote: "The best sound for music is 14hz/hi damping. High damping has less ringing and it has a much more gradual roll-off."
THANK YOU Brian! Great customer service, as always!
kevin
