Try this,you'll need a tape measure and a decent spl meter. Measure the actual distance from your LP to each speaker. Go into manual set-up and enter those distances. Use the subtuner2 to set the sub distance. Turn the volume up to around -15 and turn the test tone on.Using the spl meter at your LP,adjust the levels(in manual set-up) so they all read the same on the meter(when you select each speaker,the test tone will stay on that speaker). It doesn't matter what number the meter reads,as long as it reads the same for all speakers. Be sure that all speakers are set to small. You've just out-YPAOed the YPAO! Enjoy!
I never said to enter the actual(physical) distance of the sub into the manual set-up. I think we're saying the same thing.
Next was Das Boot, the depth charges scenes...WOW!!! Music wise I'm hearing bass that I haven't heard before. The guys on the Shootout? They were right on with what they said, "incredibly powerful sub" Now here's my question...
peace,brother
